Car won't start... Engine doesn't even turn
Old Mar 12, 2010 | 08:18 AM
oifish's Avatar
Car: 1992 Camaro Z28
Engine: 5.7 TPI L98
This happened about 6 months ago and I thought I had fixed it. When I tried to start my car the engine doesn't even attempt to turn over. The battery is fine, fan, lights, and stereo all turn on. 6 months ago I replaced the starter solenoid and the problem went away. Today it happened again. I assume it's something with the ignition system. Thanks for any help.
Old Mar 12, 2010 | 02:23 PM
InfernalVortex's Avatar
Car: 1992 Camaro RS
Axle/Gears: 9-bolt 3.70
Re: Car won't start... Engine doesn't even turn
If it's not turning over then it's irrelevant to the ignition.
Check for VATS issues and check for 12v to the purple wire going to the starter when you hit the key. I can guarantee you it's not getting 12v when you hit the switch, so you need to figure out why.
Old Mar 12, 2010 | 02:59 PM
MADMAXGTA's Avatar
Car: 89 TTA
VATS was my 1st thought to.Had it happin to me a few times,wire inside the column breaks off from the key cylinder.
Old Mar 18, 2010 | 08:08 AM
oifish's Avatar
Engine: 5.7 TPI L98
Replaced the key cylinder and it started....the wires on the cylinder looked ok, no breaks or cuts. Hopefully this problem doesn't return.
Spyder_TheGamer
Dec 25, 2015 05:07 PM
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
Wade787b
Sep 29, 2015 01:15 PM
hokis
Aug 9, 2015 03:57 PM
BrianI
Aug 9, 2015 11:52 AM
