350 TPI and 350 TBI engine specs
Old Mar 14, 2010 | 05:44 AM
QuickS10's Avatar
Hi all, new to the site. I've been reading quite a bit thru all the information on the board. I'm real familiar with the "old" 350 sbc, not the new fuel injection stuff. Does anyone know the specs of the stock TBI and TPI engines? Such as stock comp ratios, head cc's.
I have a cherry 1970 350 4 bolt main short block sitting here with 18k on it and wanted to use that for the build. I know i will need to use a retrofit kit for a roller cam that is computer friendly. What i'm trying to do is see which pistons, head combo to use to get near factory compression to bolt on the TPI injection system. I plan on using the FIRST TPI system.
Thanks in advance.
Old Mar 15, 2010 | 04:39 PM
QuickS10's Avatar
Re: 350 TPI and 350 TBI engine specs
I guess i'll try finding the info out online
MustangBeater20
Oct 29, 2022 09:20 PM
Vintageracer
Jan 10, 2020 05:33 PM
wruiz
Aug 13, 2015 09:07 PM
gta power
Aug 13, 2015 06:15 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
