loosing battery power
Old Mar 14, 2010 | 09:52 PM
houseumbrella's Avatar
Car: 1992 Camaro RS
Engine: 305 Throttle Body Injection
Transmission: Turbo-Hydramatic 700R4 four-speed
when i bought my 92 camaro rs (305) i had to immediatly get a new battery the first day of owning it. that was about 6 months ago. i replaced the alternator and the battery still goes dead. i need help if i'm gonna build this car, but don't even know where to start. i'm losing power SOMEWHERE, but not exactly sure where. any ideas??
Old Mar 14, 2010 | 10:30 PM
DemonYusuke's Avatar
Car: 1991 z28 L98 Spec
Engine: 5.7 350 TPI 245\345
Transmission: 700 R4
Re: loosing battery power
when you shut the car off next time, open the back hatch and see if the fuel pump keeps running, if it stops next try starting the car the disconnecting the positive terminal of the battery and see if the car shuts off if it does you have a bad alternator, sometimes the stock radios draw too much power, the starter wires could be rubbed raw and draing the battery
Old Mar 14, 2010 | 10:38 PM
Car: 1992 Camaro RS
lol my hatch doesnt open right now...the alternator was tested and works, and should i get a new starter, or just rewire it??
Old Mar 14, 2010 | 11:21 PM
then you should get under the car and listen for the pump, just check all the wiring to the starter for cuts, burn marks, or freying. if the starter is functioning normally i would just replace the wiring if its bad
Old Mar 14, 2010 | 11:28 PM
Car: 1992 Camaro RS
i've seen replacement electronic Holley fuel pumps at autozone. if i get one of those to replace the one i have (IF it's bad) would that give me more power?
Old Mar 14, 2010 | 11:33 PM
no, because your throttle body would just send the excess right back to the tank
Old Mar 14, 2010 | 11:41 PM
Car: 1992 Camaro RS
i'm not noticing any chugging or over-accessive use of fuel lately. are you sure that the fuel pump could be a factor even if it seems to be behaving normally?
Old Mar 19, 2010 | 09:16 PM
V6F1R3BRD's Avatar
Car: 1988 Firebird - 1998 Z28
Engine: 2.8 - LS1
Originally Posted by DemonYusuke
The starter wires could be rubbed raw and draing the battery
That's exactly what i discovered was wrong with mine today.
Old Mar 19, 2010 | 09:47 PM
skirkland1980's Avatar
Car: 82 S10, 83 280ZX, 84 Z28
Engine: 355 smallblocks..na, 2.8 turbo
Transmission: 85:th350, 84:700R4
Axle/Gears: 85:ford9 4.85, 84:stock 3.24
connect a volt/ohm meter inline with one battery cable and check for a draw with the engine off. you need .5 amps or less
Old Mar 19, 2010 | 10:22 PM
chas0218's Avatar
Car: 86' IROC
Engine: 388
Transmission: Built 700r4
Axle/Gears: 3.08 non-posi
the starter wires could be rubbed raw and draining the battery
exactly what happened to me last year. haha
BRoss99
Aug 10, 2025 05:08 PM
sailtexas186548
Aug 24, 2015 10:11 PM
Rakim_RS25TH
Car Audio
Aug 20, 2015 06:22 PM
Dialed_In
Aug 20, 2015 01:45 PM
stalkier
Aug 13, 2015 12:59 PM
