2K+ rpm Vibration
Old Mar 20, 2010 | 04:27 PM
Crazy88's Avatar
Car: 1992 B4C 1LE, 1992 5spd TBI
Engine: 400, 305
Transmission: Tremec 3550 TKO, T5
Axle/Gears: 12 Bolt Moser 3.73, 10 Bolt GM 3.08
2K+ rpm Vibration
It happens in all gears plus park and neutral. I have replaced the engine, motor mounts, transmission, converter, flexplate. i had a 350 in it before and now a 400 and i do have the right balancer and flexplate on it. i need help on maybe what else it could be. i looked to see if it was touching anywhere on my car but i didn't see any. could maybe the motor mount be bad because they were new when i put the 350 in before the 400 and it did it with both engines? bad harmonic balancer? anything helping would be great Thanks
Old Mar 20, 2010 | 05:05 PM
LS7Roc's Avatar
Car: 88Roc Flame Red Black/Gold Pkg
Re: 2K+ rpm Vibration
I have the same problem. I just started a new thread on it too. Let's see what the pros have to say.
Old Mar 21, 2010 | 02:10 PM
QuickStyle's Avatar
Car: 91 Z28
Engine: 383 SuperRam
Transmission: ProBuilt 700r4
Axle/Gears: G92 3.23
what mounts did you use, poly urethane mounts will cause a bunch of vibration.
Old Mar 22, 2010 | 12:23 PM
Rayzor32's Avatar
Car: '89 IROC-Z
Engine: 355
Transmission: 700r4 edge 3000 stall
Axle/Gears: 9-bolt 3.73
Were these brand new balancer and flexplate? Maybe one of the weights came off.
Old Mar 22, 2010 | 02:30 PM
xX89RSXx's Avatar
Car: 1989 Camaro RS
Engine: 305 TBI
Maybe bad u-joints or driveshaft? You said the tranny was replaced, did you replace u-joints?
Old Mar 22, 2010 | 02:34 PM
Rayzor32's Avatar
Car: '89 IROC-Z
Engine: 355
I think we can rule the drive shaft and u joints out because he said it still does it in neutral and park.
Old Mar 22, 2010 | 02:59 PM
xX89RSXx's Avatar
Car: 1989 Camaro RS
Engine: 305 TBI
LOL guess that didn't soak in.
Old Mar 22, 2010 | 04:34 PM
Crazy88's Avatar
Engine: 400, 305
the flexplate was new with the tranny. the balancer has been the same. i just tried the torque converter turning to the next bolt and i think i found a good balance point. hopefully this is it. thanks
Old Mar 25, 2010 | 06:25 PM
LS7Roc's Avatar
Update?
Old Mar 25, 2010 | 09:24 PM
mikeirocz1's Avatar
Car: 91 RS and 88 IROC-Z
Engine: 305 TBI and 383 Carb
Transmission: 700R4/2200 stall & 700R4/3500 stall
Axle/Gears: 3.42 posi and 4.11 posi
I would check harmonic balancer.
69GTOby
Apr 18, 2016 02:34 PM
sac92transam
Oct 7, 2015 02:31 PM
roysatikas
Sep 22, 2015 08:15 PM
BWilcox
Sep 20, 2015 12:19 PM
InfinityShade
Sep 18, 2015 08:32 PM
