89 5.7tpi won't start on it own.
Old Mar 21, 2010 | 05:34 PM
mikes89GTA's Avatar
Car: 1989 Trans am GTA
Engine: 5.7TPI
Transmission: 700r4 EAT MY SHIFT
5.7 tpi will not start without starting fluid but once started it stays running. Once warm the motor will restart. As soon as it cools right back to the no starting issue Please help
Old Mar 21, 2010 | 05:51 PM
Gregzz4's Avatar
Car: '78 GMC Sierra Heavy 1/2
Engine: GMPP ZZ4 Q-Jet
Transmission: 700R4 Stage 2 w/Race Internals
Axle/Gears: 10 Bolt 3:42 Eaton
Re: 89 5.7tpi won't start on it own.
Sounds like your prime circuit from the ECM is not functioning
Once you get it running the oil pressure circuit takes over and powers the fuel circuit
Until someone chimes in you could do some searching here as I have seen many threads that touch on this
Old Mar 21, 2010 | 06:53 PM
mikes89GTA's Avatar
Engine: 5.7TPI
I did research it sounds like simular issue in another post . magnetic pick up sensor in the distribitor. Thanks i will keep reading.
Old Mar 27, 2010 | 04:32 PM
mikes89GTA's Avatar
Engine: 5.7TPI
So after changing the distrib, cap, rotor still wouldn,t start on its own next checked the IAC vavle seem to be fine then check the MAF, TPS and finnally changing the injectors.Old ones ohmed out from 5.6 to 16 changed them all.
163.00 form amazon pyhthons 24lb/hr then readusting the distrb and timing.
The car now starts on its own .
New problem The motor seems to run very nice have it idling about 750rpms
as long as i dont punch it it runs great. when i punch it or get heavy on the throttle the car wants to stall or bucks but as soon as i let off runs great. Should i retime the car? Plaese help.
Derick15
Sep 17, 2016 05:28 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
Brcharrelson
Aug 26, 2015 07:47 PM
justin57
Aug 20, 2015 07:05 PM
killer777
Aug 8, 2015 02:47 PM
