bad charging after new pulley`s
Old Mar 22, 2010 | 11:47 AM
Iroc-Dennis's Avatar
Car: camaro iroc-z
Engine: 355 L98 Corvette engine
Axle/Gears: 3.27 9 bolt borg warner
hello all
my engine is running now after the tpi to carb swap.
i have see that the alternator is bad charging at idle!
when i give a little more gas on the throttle they charging good!
i have a mid mouth pulley set from march.
alternator pulley (the alternator is a 140 amp)
crank pulley
P/S pulley
the waterpump is a electric one
what is my problem here and how can i fix it!
many thanks dennis
Old Mar 22, 2010 | 12:48 PM
built91Z28's Avatar
Car: 1991 Camaro Z28
Engine: 357, Canfield heads, solid roller,
Transmission: Upgraded 03 Cobra T56
Axle/Gears: 9" 3.50 gears and Detroit Locker
Re: bad charging after new pulley`s
If they are underdrive pulleys then there really is no problem. Underdrive pulleys are known for this. If you only need to raise the idle 100 RPM's or so then you could just try raising the actual idle RPM so the alternator will charge.
Old Mar 22, 2010 | 01:19 PM
InfernalVortex's Avatar
Car: 1992 Camaro RS
Axle/Gears: 9-bolt 3.70
Thats pretty much how underdrive pulleys work. Less drag on the rotating assembly for more power. The alternator will charge less because it's not turning as fast.
Old Mar 22, 2010 | 04:14 PM
Car: camaro iroc-z
okey i understand that!
is there a pulley that i must buy to fix the problem!
the alternator must turn faster to charge!
this is the pulley kit i have!
http://cgi.ebay.com/ebaymotors/March...Q5fAccessories
Old Mar 22, 2010 | 04:30 PM
TADailyDriver's Avatar
Car: 1988 Trans Am, 2005 Sierra 2500
Engine: Vortec 357
Transmission: Built TH700R4 with 26-2800 Stall
Axle/Gears: GM 10 bolt 3.73 Posi
Like it was said before just adjust the idle so that the engine idles higher thus putting out more rpms so the rotation of the alternator is faster thus causing it to charge better. I had the same problem and adjusting the idle fixed it.
Old Mar 23, 2010 | 09:45 AM
305sbc's Avatar
Car: 1986 Irocz
Axle/Gears: 3.25:1
You need to use your stock alternator pulley or the March Overdrive pulley.
If you then still have a problem, then tighten the belt more, or switch to an external adjustable voltage regulator for your alternator.
Pics:
http://s702.photobucket.com/albums/w...adis3/Pulleys/
Hotrodboba400
Dec 10, 2019 07:07 PM
83 Crossfire TA
Jan 3, 2016 01:26 PM
BDR
Nov 7, 2015 03:05 PM
Johnoooooo
Sep 22, 2015 08:55 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
