Fuel pressure problem
Old Mar 25, 2010 | 12:54 PM
joebeagle's Avatar
Car: 1991 RS Convertible
Engine: 5.0L
Transmission: Standard
'91 camaro, 305 with TBI. I'm having a problem with a hard start when the engine is cold PLUS now the car is cutting off when you decelerate. Borrowed a fuel pressure gauge from Auto Zone. Pump does not prime when you turn the ignition on. Takes about 10 seconds for the pressure to build up while cranking. When running at idle, fuel pressure is about 10 PSI. Followed the diagnostic instructions in the service manual. Put 12 volts to the fuel pump relay, pump came right to life. Changed out the fuel pump relay with a new one. Fuel pump still does not prime with the new relay. Now takes about 2 seconds of cranking for the fuel pressure to come to life. Still stalls at deceleration. Any suggestions?
Old Mar 25, 2010 | 09:00 PM
joebeagle's Avatar
Engine: 5.0L
Re: Fuel pressure problem
I've isolated the problem down to the link between the ECM and the fuel relay. I have replaced the ECM recently (3 weeks ago) so that should be fine? Once again, any thoughts?
Old Mar 26, 2010 | 02:42 PM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Cranky Engine
OK if you’ve solved the long cranking time problem, you just have the idle problem.
You should scan for codes as the first step.
Happy Racing!
How bout those too scared to drive without headlights in the daytime and the ones that need headlights for a little rain
Old Mar 26, 2010 | 03:30 PM
joebeagle's Avatar
Engine: 5.0L
Re: Cranky Engine
That's easy. Code 54.
Old Mar 26, 2010 | 08:15 PM
joebeagle's Avatar
Engine: 5.0L
Re: Cranky Engine
Does anyone know where the reference pulses are supposed to come from?
Old Mar 29, 2010 | 11:36 AM
NINÅ's Avatar
Transmission: 765R4
Referee
The reference signal comes from the ignition module and is sent to ECM-B5.
Happy Racing!
“I Didn’t Jump The Start, The Flagman Was Late”
Old Mar 31, 2010 | 07:33 AM
joebeagle's Avatar
Engine: 5.0L
Re: Referee
Thanks for the help. The new ECM I bought was bad. Car fired right up after I exchanged the ECM.
92camaroJoe
Jul 29, 2023 07:57 PM
Infested
May 22, 2018 11:56 PM
wayshegoes
Aug 17, 2015 12:00 PM
92camaroJoe
Aug 13, 2015 06:07 AM
Kaweh
Aug 9, 2015 02:54 PM
