Cutting the credit card key.
Old Mar 26, 2010 | 02:05 PM
darkhorse91's Avatar
Car: 91 B4C/91 RS 305
Engine: L98 and L03
Transmission: 2xTH700R4
Axle/Gears: 3.23 LSD/2.73 Open
did anybody get the little plastic credit card with a key in it? if so do you know where I could get it cut? i just locked my keys in my car and had to deal with that whole spiel, but they're free now and I would really like to use the credit card key in case it happens again, or getting a spare is always an option but this thing is pretty cool.
Old Mar 26, 2010 | 02:27 PM
I H8 WWD's Avatar
Car: 89' IROC-Z
Engine: LO3
Axle/Gears: 10-Bolt/2.73
Re: Cutting the credit card key.
Like this?
https://www.polkslockservice.com/sho....php?groupid=3
My trunk and door key is a letter 'D' key.
Old Mar 26, 2010 | 02:43 PM
Engine: L98 and L03
kind of but mine looks like this. (except not flipped backwards, stupid photo booth) it has a 8014 and GM-H stamped on the back of the key.
Attached Thumbnails Cutting the credit card key.-photo-2010-03-26
Old Mar 26, 2010 | 03:08 PM
I H8 WWD's Avatar
Car: 89' IROC-Z
Engine: LO3
Don't quote me on this but that looks like something you can only get from the Dealer. Have you tried calling a Dealer to see if they can get you one? I'd start with that.
An extra key is definitely something I need, my keys always fall out of my 5th pocket (wish I had six pockets) and hit the ground, and having only 1 VATS key scares me every time they fall.
How about getting something like this.
http://sportys.com/PreferredLiving/p...=Google%20Base
I don't like the magnetic ones, sort of get that feeling its no longer there.
Old Mar 26, 2010 | 05:10 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Given that it doesn't have the chip in it and you have a 1991, it'll only serve to unlock the door - so there's no point having it cut for the ignition key.
I would think any locksmith could cut it for the door key.
Old Mar 26, 2010 | 09:08 PM
Damon's Avatar
The plastic key only does the door and trunk anyway. Ignition uses a square-head key. Never saw much point in the plastic key anyway- it's not any thinner than a metal one.
Unless the dealer will cut the plastic key for free (doubtful), get a real metal key cut by them (they can do it for you sight-unseen if you supply the vin and title, proving ownership). I forget what it cost, but $20 comes to mind. Worthwhile investment since it will be a NEW key, cut to factory spec, not copied from a worn-out original.
Old Mar 27, 2010 | 03:13 PM
krisb410's Avatar
Car: 91 RS Camaro, 75 L82 Corvette
Engine: LO3, 383 Stroker
Transmission: 700R4, TH400
Axle/Gears: 4th gen 3.23 posi/LS1 discs, stock
Don't forget the lock mechanism is old (and may be worn as well). I've seen instances where a fresh key cut doesn't work, but a copy of the old key works. Eitherway, any home depot or lowes will copy a key for a few bux
Old Mar 28, 2010 | 11:36 AM
rayar's Avatar
Car: 83 Camaro
Engine: 4 Bolt 350, Bowtie aluminum heads
Transmission: TH350
Axle/Gears: 3.42, superior axles, Torsen diff
Worked in a dealership for 6 years and never cut a GM plastic key. We also sold Toyota and they also have credit card keys and required a special cutter. Allthough I think the modules from our main cutter would have fit in that machine so we could have cut the GM keys also. We could only cut the credit car keys off of an exsisting key. The cutter for the credit card keys had a finer cutting wheel but I don't see why a regular cutter wouldn't work. BTW, Toyota required us to cut the credit card keys free of charge. The only time I would charge a fee was if we had to cut a key from the VIN, GM started requiring that we keep documentation on every key we cut from the VIN and it was just a bit of paperwork but was a total PITA.
3rd gen money
Oct 11, 2019 09:57 PM
RS Reaper
Oct 17, 2018 07:52 PM
Gunner242
Dec 25, 2015 04:49 PM
gord327
Oct 3, 2015 01:25 PM
3.8TransAM
Sep 27, 2015 08:37 PM
