Car pushed backwards while in drive(accident)
Old Mar 29, 2010 | 03:52 PM
JLP's Avatar
JLP
Car: 1983 Trans Am
Engine: 305 LG4
Just wondering, would my car have any extra damage other then the exterior if another vehicle pushed mine from the front and moved it backwards while in drive???
Like the torque converter or something...
Sorry Im not the greatest mechanic.
Old Mar 29, 2010 | 03:55 PM
KNBlazer's Avatar
Car: Trailblazer EXT 4.2 (Firebird Form)
Engine: 5.1 4bbl
Transmission: 700R4 Mega Raptor Level 4
Re: Car pushed backwards while in drive(accident)
the transmission could have suffered internal damage, but not sure...
Old Mar 29, 2010 | 05:40 PM
Grumbles's Avatar
Car: 1978 Chevrolet impala
Engine: 350ci 300hp/356tq pace crate
Axle/Gears: 3.42 Yukon posi
A better question to receive more in-depth answers would be: are you experiencing any new problems while driving?
Old Mar 29, 2010 | 06:57 PM
Rolling Thunder's Avatar
Car: 86 T/A, 83 Z/28
Engine: 5.0 TPI, 350 2 X 4 bbl
Transmission: 4 speed auto, 5 speed manual
Axle/Gears: 3.23 posi, 3.73 std
I wouldnt be too worries about driveline damage i would be more concerend about the frame. I would measure the frame and compare it to the specs in the factory manual.
Old Mar 29, 2010 | 07:43 PM
The_rabbit1's Avatar
Car: '87 Iroc
Engine: 350 .060 over
Axle/Gears: 3.70 9bolt
and while your at it check your tire pressure.
really? as long as you weren't mashing the gas causing the torque converter to grab and the car didn't push you at 25mph backwards the transmission should have enough slippage to let it slide, kind of like letting go of the gas on a hill and watching the car roll back while in drive.
Old Mar 29, 2010 | 07:59 PM
JakeJr's Avatar
Car: 1996 Vette / 1992 GSX1100F Suzuki
Engine: 1996 Corvette Coupe 388 LT1 (+.060)
Axle/Gears: 3.07
I never came across a full explanation of that but I know it's one of the things the NASCAR boys worry about after being involved in an accident. Of course those are manual trans cars, so that could be the difference.
Something to do with causing the engine to run backwards.
Jake
Old Mar 29, 2010 | 08:03 PM
campin1983's Avatar
Car: 1984 Camaro 'Vert
Unless you have some serious rubber on those tires (like NASCAR, as mentioned previously in this thread) I'd imagine the tires woulda slipped before there was drive line damage.
Old Mar 29, 2010 | 10:30 PM
Grumbles's Avatar
This.
Old Mar 30, 2010 | 06:40 AM
3rdgenmaro's Avatar
Car: 88 IROC
Engine: 97 5.7 Vortec LT4 hotcam
Transmission: 700 r4
wouldnt get any oil, could cause bearing damage
Old Mar 30, 2010 | 08:14 AM
///DAN///'s Avatar
Car: 1984 camaro Z28
Engine: 355 SBC
Transmission: 700 r-4
Axle/Gears: Strange 3:73 posi
in nascar if they don't hit the clutch when sliding backwards they run the chance of bending valve train it will bind the engine because the clutches they use are sooo tight.
Old Mar 30, 2010 | 05:02 PM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
Ive stuck automatics in reverse before when driving (by accident, of course). It usually just causes the engine to stall, which causes the front pump to stop turning, which then causes teh clutches/band to disengage, effectively putting the car in neutral. The other possibility (if you have your foot down to the floor), is that it causes the car to loose control. I suspect most of the damage was to the front end (front crash bar, headligh support, etc).
BlueIroc-Z
Jun 9, 2019 03:22 AM
Azrael91966669
25
Jun 20, 2017 04:04 AM
Armored91Camaro
Aug 12, 2015 09:41 AM
Tony Ferrarri
Aug 11, 2015 07:59 PM
gwade12
Aug 8, 2015 08:17 AM
