Valve Cover gaskets?
Old Mar 31, 2010 | 03:31 PM
Knight83's Avatar
Car: 82 Trans Am
Engine: Cross-Fire Injected 305
Transmission: 3spd Auto
Hi guys im kinda new here ( i joined up a long time ago to find a Trans Am but I haven't started really working on it til now ) and need a little help.
I have a 82 Trans Am CFI that i bought off of a member in the fall of 08. I have not had the money to do anything with it til recently and am trying to get it back on the road. The thing does feel like it needs a major tune up but im getting a good amount of smoke coming off the Valve covers. Is there a quick how-to on here anywhere for the best way to go about replacing them? I did a search and couldnt find what i was looking for.
Im a bit of a beginner on cars as the only thing i have ever really done to my cars was oil changes n what not.
Old Mar 31, 2010 | 03:44 PM
Grumbles's Avatar
Car: 1978 Chevrolet impala
Engine: 350ci 300hp/356tq pace crate
Axle/Gears: 3.42 Yukon posi
Re: Valve Cover gaskets?
Valve cover gaskets are pretty self-explanatory. You just unbolt the valve covers, remover/scrape gasket as needed, and replace.
Old Mar 31, 2010 | 03:59 PM
I H8 WWD's Avatar
Car: 89' IROC-Z
Engine: LO3
Axle/Gears: 10-Bolt/2.73
It really is that simple. Get yourself some Rubber Fel Pro Gaskets and you'll never have to replace them again, unless you fudge them up somehow.
Have fun.
Old Mar 31, 2010 | 04:26 PM
Knight83's Avatar
Car: 82 Trans Am
ok , i didnt know if there was a procedure to it like draining the oil first or what is safe to remove and what isnt. The drivers side looks straight forward and easy enough but the passenger side........not as much.
Drivers side
Passenger side
Old Apr 9, 2010 | 07:50 PM
lordmetalz28's Avatar
Car: 1987 Z28 with iroc-z Package no.3
Engine: 350TPI
Axle/Gears: 3.73 posi
good luck getting those garbage fel-pro rubber gaskets to stay in the cover while you fool with putting it back on the head!!!
Old Apr 10, 2010 | 12:19 AM
87IROC-DAN61's Avatar
Car: White 1987 IROC-Z
Engine: 305 TPI LB9, 215 HP
Transmission: Borg-Warner T5 NWC
Axle/Gears: Borg-Warner 7.75 with 3.27 ratio
Drivers side
Passenger side
Hello Knight83!!
You can leave the passenger side alone, if it's not leaking!!
If you do decide to tackle it, just take lots of pictures so that you know where things go, and in what order, and just be gentle, don't force things beyond their limits!!
Take your time......it's easily done!!
Old Apr 10, 2010 | 12:25 AM
Hello lordmetalz28!!
A little bit of prep work (clean up the oil with a good degreaser) on the valve cover lip, and some gasket adhesive does the trick!!
The secret is to wait until the adhesive actually sets up, before you try to put the valve cover back on!!
db057
Sep 4, 2015 07:57 AM
Victor6
Aug 30, 2015 02:09 AM
g.l.mos
Aug 22, 2015 12:02 AM
86White_T/A305
Aug 17, 2015 12:16 AM
mustangman65_79
Aug 8, 2015 01:18 AM
