Umbrella Seals
Old Mar 31, 2010 | 06:17 PM
Blind Driver's Avatar
Car: 1986 Trans Am
Engine: 5.0
Axle/Gears: beats me
Umbrella Seals
I'm having some smoking issues so while my valve covers are off, they are getting replaced. But no one locally knows what I need. Do I want then improved 0-ring version? Does anyone have a part number? I don't want to order the wrong ones
I didn't see any threads specific to the seals.
Old Mar 31, 2010 | 06:34 PM
Atilla the Fun's Avatar
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Re: Umbrella Seals
exhaust valves get these:
http://www.competitionproducts.com/V...ductinfo/5100/
while intakes get these:
http://www.competitionproducts.com/P...uctinfo/S5325/
you can get 8 of each at any local machine shop
Old Mar 31, 2010 | 07:31 PM
UNCLE TOM's Avatar
Car: 91 R/S , 89 dodge p/u
Engine: L31 GM crate re-cammed , 318
Transmission: T-5 , 4 speed auto
Axle/Gears: 3.42 , ?
Re: Umbrella Seals
you should be able to find them at any major auto parts store . the last set i got was from NAPA . good luck .
Old Mar 31, 2010 | 07:41 PM
greatskiiiier's Avatar
Car: 98 z28
Engine: ls1
Transmission: t56
Axle/Gears: 12 bolt/ 4.11
Re: Umbrella Seals
the only 2 set of heads ive rebuilt both have the second one pictured on all 16 valves
Old Mar 31, 2010 | 07:49 PM
Car: 1986 Trans Am
Engine: 5.0
Re: Umbrella Seals
That's what I'm thinking. I need to check out NAPA. I keep forgetting about them
Is there a reason to use two different styles? It's a old engine that may be swapped out this winter, but I don't like leaving a smoke trail
Old Mar 31, 2010 | 08:27 PM
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Re: Umbrella Seals
I'm too tired to go in depth this evening. I do this for a living, I've sent thousands out the door the way I said, I've never once had any problem from it. It is correct or I wouldn't say it. If you want the in-depth, ask again tomorrow.
Old Apr 1, 2010 | 07:29 AM
Car: 98 z28
Engine: ls1
Transmission: t56
Re: Umbrella Seals
not saying its incorrect, just saying the only heads... 2 sets... ive done a complete overall on, only used the second umbrella and 1 also used the orings on top of the valves, and the kit i bought from summit only came with the second set of seals
so from my experience either will work, but you're the pro not me
Old Apr 5, 2010 | 08:35 AM
Car: 1986 Trans Am
Engine: 5.0
Re: Umbrella Seals
I ordered th complete o-ring set from Summit for the low price of $14.95. They shouldbe here for the weekend wrench turning session.
1Aauto
Sponsored Vendors
Oct 19, 2016 08:50 AM
1Aauto
Sponsored Vendors
Oct 13, 2015 03:06 PM
