distrib help
Old Apr 5, 2010 | 07:30 AM
84z5350's Avatar
Car: 1986 z28
Axle/Gears: ?
distrib help
i recently swapped from tbi to carb i almost have all the bugs worked out but when i went to swap the gears on the distributer from origanal 1 to the hei the gears look identical but the shaft hole is smaller on the small cap fuel injected dist i need the part # for the right gear so i dont chew **** up this is a 92 rs gone carbed want to run big cap hei on roller cam cam any one help?
Old Apr 5, 2010 | 02:12 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Exactly what distributor are you putting in?
Old Apr 5, 2010 | 02:29 PM
84z5350's Avatar
Car: 1986 z28
Axle/Gears: ?
Re: distrib help
i will b installing summits very own gm hei with steel gear friend had it sitting on shelf for a few years the engine it was bought for is running hyd lifter cam not sure if it is compatable i tried to switch gears from the stock dizzy but the main shaft diameter is smaller so they wont interchange do you have a part # for what i need?
Old Apr 5, 2010 | 02:44 PM
five7kid's Avatar
It'll be fine.
gta892000
Aug 11, 2019 11:16 AM
83z28-350
Aug 2, 2002 07:43 PM
Ray87Z
Nov 7, 2001 04:33 PM
BitchinRS
Aug 20, 2001 10:10 AM
JPrevost
Apr 3, 2001 02:53 PM
