V.6 3.1L Help
Old Apr 7, 2010 | 08:21 PM
YoungMoneyVII's Avatar
Car: 1990 Pontiac Firebird T-Tops
Engine: V8 350 5.7 L TPI
Transmission: Overdrive 700R4 (Auto)
Axle/Gears: 9 Bolt/GU5AXLE,REAR3.23 RATIO3.23R
V.6 3.1L Help
ive been taking my v6 3.1 1990 firebird and ive taken off all of the pulleys except for the water pump and another pump thats on the bottom left that was under the alternator, im not sure what its for but my friend said it goes to the EGR. Also ive been trying to get the dash board piece off but im not sure how many bolts are under the drover side. Also had a problem getting the heater core box cover off feels like theres still a bolt uptop i cant find. Was also wonder if its ok to take the 2 small bar pieces crossing that are infront of where the condenser would go. I also broke some things and help need knowing what they are, one was a 3 way plastic piece of the cooling system with hoses going into it and one of the plastic ends cracked off because a fastner was too tight. Another piece i broke was a small connecter piece of the ac canister that looks like a modern appliance plug. thx guys
Old Apr 8, 2010 | 01:35 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Are you just taking the car apart for kicks, or what are you trying to do?
The pump sounds like the A.I.R. pump. There is no such thing as an EGR pump.
If something feels like it still has a bolt holding it on, it probably does.
It may be helpful if you had pictures of what you're asking about.
jhawkeye
May 25, 2022 06:33 PM
HoosierinWA
Oct 7, 2015 10:15 AM
MitcherNeaf
Sep 24, 2015 09:23 PM
WIzmo
Aug 30, 2015 02:30 PM
92projectcamaro
Aug 6, 2015 01:20 PM
