Failed emissions w/gutted cats
Old Apr 14, 2010 | 02:09 AM
BlueByU's Avatar
Car: 1991 Z28
I have gutted cats. I'm trying to pass emissions w/o cats...or at least get my car running properly before I do put on cats.
I failed emissions again on my 2nd attempt, I improved my HC and NOX by a lot. Since my first attempt I have cleaned the K&N air filter, new spark plugs(AC Delco), seafoamed, changed PCV, disassembled and cleaned out entire intake/throttle body, and made sure EGR was working.
My CO is still way too high. I did some searching and found that high CO results from rich air/fuel mixture. I have 24lb. SVO fuel injectors and my car is basically stock minus catback. My injector constant is set at ~25.3. So, I'm thinking my problem could be the fuel injectors are still delivering too much fuel. Should I try increasing the injector constant? What else can I do to lean out my air/fuel ratio? I can burn a new chip if needed. I'm going to hook up the AutoProm tomorrow and record some data, hopefully you guys can help my decipher it though.
LATEST TEST
Code:
          | MY EMISSIONS| LIMITS   |RESULT|
   HC     |     1.02    |  1.00    | FAIL
   CO     |     28.37   |  12.00   | FAIL
  NOX     |     2.54    |  2.50    | FAIL
PREVIOUS TEST
Code:
   HC     |     1.87    |  1.00    | FAIL
   CO     |     21.89   |  12.00   | FAIL
  NOX     |     4.53    |  2.50    | FAIL
Old Apr 14, 2010 | 07:22 AM
Atilla the Fun's Avatar
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Re: Failed emissions w/gutted cats
Start by dropping your fuel pressure. Don't go below 26 psi with those injectors.
Old Apr 14, 2010 | 10:15 AM
RED_DRAGON_85's Avatar
Car: 85 Camaro IROC
Engine: 5.7 TPI
Transmission: 700-R4
Axle/Gears: open rear, 3.42 gears
honestly, your only real MAJOR problem is CO, which is what the catalytic converter is primarily designed to reduce.
NOx is another big one, but you are already pretty clean there, which means your EGR is working great.
how is your O2 sensor?
if it has seen better days, replace it.
a simple cat addition will easily pull you down below the limits however
Old Apr 14, 2010 | 10:29 AM
HF_monster's Avatar
Car: 86' z28 (died 5/1/11) 76 k10 pickup
Transmission: th350
Axle/Gears: 3.73 open
as RED_DRAGON_85 stated Id start with the O2 sensor if its a one or two wire sensor go to a 3 wire self heated or a wide band sensor and that should help bring the CO levels down
Old Apr 14, 2010 | 12:00 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
I'd start by putting cats with guts on.
Doesn't make any sense to run gutted cats. None whatsoever.
Old Apr 14, 2010 | 12:47 PM
regal301's Avatar
Car: 1988 iroc-z
Engine: 350 Vortec TPI
Axle/Gears: 3.73 4th gen Torsen 10bolt
a rich air/fuel will reduce nox
lean out your fuel and your nox will go up.your already over the limit.
your wasting a lot of time,go on ebay grab 2 cheap catco cats for $45 each.clamp or have them welded on,get the sticker and then do what you want.
Old Apr 14, 2010 | 12:57 PM
Stephen's Avatar
Car: 87 GTA
Put a good, high flow cat on. You'll never miss the 2hp (at most) that you'll lose.
If you really want that 2hp back, use flanges on each end. And put matching flanges on your gutted cat too. Then you can swap the real cat on for emissions testing, then swap to the gutted one for the rest of the year.
That is most likely the quickest & easiest way to pass testing.
Old Apr 15, 2010 | 01:57 AM
BlueByU's Avatar
Car: 1991 Z28
Yeah I'll probably pass with new cats, but I'm still concerned over the air/fuel mixture being too rich which could cause the new cats to go bad quickly. New cats will only mask the problem, not fix it. I'm looking for how to fix the rich air/fuel mixture.
Old Apr 15, 2010 | 02:43 AM
KNBlazer's Avatar
Car: Trailblazer EXT 4.2 (Firebird Form)
Engine: 5.1 4bbl
Transmission: 700R4 Mega Raptor Level 4
lol.. the freakin' EPA is gonna shut us down..haha... ok well ... what about messing with your timing, at least just for the test, but yeah I would say you'd have to get new calibrations for your injectors... you may want to ask Kevin for advice, I think he's pretty good at this crap..
Old Apr 15, 2010 | 09:17 AM
Saabster's Avatar
Car: 89 Camaro RS
Engine: LO3 TBI
Transmission: 700R4 => WC T-5
Axle/Gears: 3.42 Open Diff
Get a O2 gauge and fix it if you're worried.
Old Apr 15, 2010 | 09:51 AM
KNBlazer's Avatar
Engine: 5.1 4bbl
tic toc... clock is ticking... get a temp fix so you can get your tags and then worry about the problem... I don't how emission laws are in AZ, but here in Cali you have 2 extensions IIRC, and then you're either screwed or screwed ... I think you either have to take it to a shop or to a ref in order to either get a fix or an extension... don't know this last time that it didn't pass the sniffer test, I ended up developing other problems and didn't bother to troubleshoot them, it has something to do with the Tranny... but yeah my advice is if the CATS will get you your tags then by all means jump on it...
Old Apr 22, 2010 | 04:58 PM
BlueByU's Avatar
Car: 1991 Z28
Well I passed after new cats.
Code:
   HC     |     .24     |  1.00    | PASS
   CO     |     .92     |  12.00   | PASS
  NOX     |     1.53    |  2.50    | PASS
But now I've got a new problem, the starter...
Old Apr 22, 2010 | 05:02 PM
KNBlazer's Avatar
Engine: 5.1 4bbl
Code:
DAMN!!! was all that just the CATS? no other mod to pass the test?
Old Apr 22, 2010 | 05:07 PM
84transamdude's Avatar
Car: 84 Trans Am
Engine: 383 Stroker
Transmission: Th350
man that stinks that they actualy smell whats coming out lol. here in pa they do a visual. It just has to be there and look like it works. But in my case i keep it under 5000 mile a year and its exempt. i have no emissions stuff on my car including no cat at all.
Old Apr 22, 2010 | 05:45 PM
Stephen's Avatar
Car: 87 GTA
Code:
And I'll bet your car is no slower than before, but does run better now!
Old Apr 22, 2010 | 10:45 PM
BlueByU's Avatar
Car: 1991 Z28
Yeah just 2 new cats everything else exactly the same, exact same station.
Old Apr 23, 2010 | 05:45 AM
Saabster's Avatar
Car: 89 Camaro RS
Engine: LO3 TBI
Could it be that gasoline engines have nasty emissions and that cats magically (scientifically) fix it?
Old Apr 23, 2010 | 09:43 AM
Grumbles's Avatar
Car: 1978 Chevrolet impala
Engine: 350ci 300hp/356tq pace crate
Axle/Gears: 3.42 Yukon posi
No real time problem in AZ. My car sat for about 2 years with no tags at all, not even registered.
Old Apr 24, 2010 | 10:39 PM
midge54's Avatar
Car: 86 Trans am
Engine: LG4
Axle/Gears: 3.27 9 bolt posi
Hey your not too far from me, i live about 20 mins west of gettysburg, but Yea i love Pa emission laws franklin county is strictly visual checks and if its in a emissions county and its older than 95 its still visual. My 89 Z24 had never had operating cats on it and i plan on yanking the cats outta my 15th Trans am once i get it running cause ive seen too many cats get clogged working in the shop. And as long as i keep my inspection and emissions license up to date i wont have to worry about passing
LT1Formula
Oct 8, 2015 08:34 PM
jaridjohn
Oct 5, 2015 07:01 AM
