1:6 rockers?
1:6 rockers?
i have 87 iroc and apparently some one replaced lb9 w/what i believe is a mid 80's flat tappet 305 w/416 heads.anyone know if i can just add 1:6 rockers w/o any issues and how worth while or noticeable powerwise would it be?thanks!still has stck tpi setup.
Car: 1992 Camaro RS
Engine: 305 TBI
Re: 1:6 rockers?
1.6 should work as long as you have enough spring clearance between the coils. Be sure to check before you fire the engine up.
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
Re: 1:6 rockers?
1.6's will be fine on a stock setup. No clearance issues. All that factory equipment was way to small. Handful of HP gain.
Cam swaps aren't a walk in the park, depending on what tools you have available. Depending on what cam would go in, it's the tuning that's more or less the 'fun' part. Also, with stock heads, you're stuck at .480"ish, sometimes less, of lift that you can safely run before retainer-to-guide boss interference. So this kind of limits cam selection to begin with.
New2Chevy
Sep 28, 2015 12:35 AM
