Power steering flush
Old Apr 28, 2010 | 06:22 PM
joshwilson3's Avatar
I'm looking at flushing the power steering on my 89 Firebird.
In the pic below, am I supposed to put the clear line on that metal line that is inside the red circle? Then the other end of the line goes to a bucket, and I turn the wheel back and forth to flush it.
Or does the line coming from the power steering pump/reservoir that runs to the bucket?
And anyone recommend a power steering fluid from the local auto parts store?
Old Apr 29, 2010 | 09:56 PM
Re: Power steering flush
Bump.
Old Apr 30, 2010 | 07:59 PM
Mr Froman's Avatar
Car: 1990 Firebird Formula
Engine: LB9 - 5.0 TPI
Axle/Gears: 2.73, LSD
I wanna know this too. I'll look in my chilton tomorrow but for now BUMmmMmp
Old Apr 30, 2010 | 09:35 PM
I think that is right, as that is the return line. But just want to make sure.
If that is right, then you'd need to pinch off that return hose that is on the pump to keep fluid from coming out while you are flushing I believe.
Then I'd replace that hose since it is old anyways, plus it would probably be damaged from clamping it shut via vice grips. It is $2 at Autozone. Plus new clamps.
Old May 1, 2010 | 04:13 PM
My Haynes doesn't say anything about flushing the power steering fluid. Just bleeding it.
So bump again.
Old May 1, 2010 | 08:06 PM
bcmag's Avatar
buy a cheap turkey baster .suck as much fluid as poss. out of reservoir add fresh fluid run and repeat process til fluid is clean.less messy this way.
Old May 1, 2010 | 09:58 PM
I've done did that. And the fluid would stay black. I probably put 2 or so quarts that way. Still black. Which is why I want to do a proper flush as you will get near all of that out and replaced with new.
Old May 2, 2010 | 06:07 PM
Bump. I guess I need to go ask this in a different forum. I was hoping to have the steering fluid flushed by now. I'd at least like to get to it next week.
Vintageracer
Jan 10, 2020 05:33 PM
colton_carlson
Mar 8, 2019 12:21 PM
Chuck84TA
Jul 15, 2016 09:05 PM
evilstuie
Apr 14, 2016 08:52 PM
deracer
Apr 11, 2016 12:04 AM
