cam specifications
Old May 2, 2010 | 08:31 AM
jean-karim's Avatar
cam specifications
Hi all!
I have a comp cam supposed agressive and advertised as 412 lift at 030 duration in my 355 chevy engine (bought the var like this). Does someone know what profil and lift that cam is at the regular 050 duration that everyone uses?
Thanks!
Old May 2, 2010 | 08:38 AM
Quick_Trans_Am's Avatar
Car: 1985 Pontiac Trans Am
Engine: 355 with stuffs.
Axle/Gears: 4.10 Posi
Re: cam specifications
That's really not enough information to know exactly what cam you have in the engine. If it's a comp cams camshaft, the part number is on the camshaft itself, however the cam must be removed from the engine for you to see it. If you have the part number, you can find all the specs for that cam.
Old May 2, 2010 | 09:59 AM
built91Z28's Avatar
Car: 1991 Camaro Z28
Engine: 357, Canfield heads, solid roller,
Transmission: Upgraded 03 Cobra T56
Axle/Gears: 9" 3.50 gears and Detroit Locker
Actually none of what you posted really makes sense. Duration is normally posted at .050" lift. Not lift at .050" duration. Also a cam with only .412 lift is not even close to being an aggressive cam.
Prodigious
Theoretical and Street Racing
35
Apr 13, 2021 02:37 PM
Jorlain
Oct 8, 2015 01:57 AM
customblackbird
Oct 1, 2015 04:30 PM
Strick1
Sep 4, 2015 07:11 AM
z28guy134
Sep 1, 2015 11:50 PM
