service engine soon
Old May 10, 2010 | 08:19 PM
grassyflats's Avatar
service engine soon
what are the typical solutions to cure
the service engine soon warning light?
and also the solutions to the more advanced symptoms
does anyone have a list of
what systems the light is a trigger for? thanks
tune up for one
what else you got?
Old May 10, 2010 | 08:44 PM
racethesunlive's Avatar
Car: '92 Camaro
Re: service engine soon
This tech article should help get you started...
https://www.thirdgen.org/service-engine-light-error-codes
Old May 11, 2010 | 01:03 PM
i have seen this posted before
the description of the flashes is still a bit obscure
can anyone shed more light on the subject in this link?
Old May 16, 2010 | 10:30 AM
the light only comes on on the highway
Old May 16, 2010 | 07:28 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
If you don't understand the flashing codes, just go to any local chain auto parts store and let them pull the codes - they almost all do it for free.
Old May 16, 2010 | 07:30 PM
itsMikey's Avatar
Car: 89 GTA/93 S13/91 Si
Engine: 5.7 350 TPI
heres what ya do...
*blink (pause) *blink *blink = code 12
*blink *blink *blink (pause) *blink = code 31
got it?
Old May 16, 2010 | 08:18 PM
xX89RSXx's Avatar
Car: 1989 Camaro RS
Engine: 305 TBI
All autozones and advance auto parts do it free!
Also, with the blinking.....code 12 will blink 3 times telling you that it is in diagnostics. Then if there is any other codes, each will also blink 3 times.
Old May 26, 2010 | 06:38 PM
I got it Mikey thanks
that is the part not described in the link
Old May 27, 2010 | 07:02 PM
autozone said they can only test 96 and later
he did give me a test key for free
cross terminals 5 and 6 not 6 and 12
okay here we go
I got code 32
EGR
did they burn a chip or what?
the only solution to egr delete
Old May 28, 2010 | 11:08 PM
okay here we go
I got code 32
EGR
consider it
Vintageracer
Jan 10, 2020 05:33 PM
backtothe80s
Sep 5, 2015 12:39 AM
Jae992
Aug 27, 2015 09:07 AM
kyleb24
Aug 15, 2015 08:24 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
