502 ram jet hyrdolic roller lifters question
Old May 13, 2010 | 09:21 AM
engongam's Avatar
Car: 1991 Trans Am GTA
Engine: 502 Ram Jet
Transmission: TKO600-racing gears
Axle/Gears: 12 Bolt Moser-33"axles-3.91 ratio
Hello,
My 502 ramjet is now making some lifter noise (I guess), I changed its oil but the sound is still there. I want to change its lifters but I am not sure which hyrdolic roller lifters to buy. Can you help me out?
In the service manual that I found http://www.crateenginedepot.com/pdfs/BB_RJ502.pdf it says that the lifter's part # is:
17120061 which is: http://www.summitracing.com/parts/NAL-17120061/
but when I do a search on Summit I got these lifters: http://www.summitracing.com/parts/NAL-12371056/
Which lifters should I buy?
Thanks...
(If you have any ideas about the sound, any suggestion would be appriciated)
Old May 13, 2010 | 09:50 AM
Atilla the Fun's Avatar
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Re: 502 ram jet hyrdolic roller lifters question
That service parts list seems to be copied directly from GM themselves, and I'd believe GM over Summit. If the new lifters don't solve it, I'll buy your old ones from you.
Old May 13, 2010 | 05:59 PM
engongam's Avatar
Engine: 502 Ram Jet
but that lifters of GM's are way too expensive relative to summits. when I order 16 gm's lifters it sums to 800 dollars with the summits advised lifters as you can see from the link its a 314 dollars kit... there is a huge difference between them.
Old May 13, 2010 | 06:01 PM
Twin_Turbo's Avatar
They are expensive for a reason, not made in china. Get the GM lifters.
Old May 13, 2010 | 07:02 PM
engongam's Avatar
Engine: 502 Ram Jet
Other option's manufacturer is GM too that's the confusing part=)
Old May 13, 2010 | 08:14 PM
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Okay, I went and researched this. Here's what I found: the GM lifters are way expensive when bought individually. GM gives a better price when you buy a set. When you do, it's a different part number, but instead of quantity : 16, you only need quantity: 1. Summit's set is fine. Save yourself the nearly $500.
Old May 14, 2010 | 03:08 AM
engongam's Avatar
Engine: 502 Ram Jet
Ok, I'm getting the GM's lifters which is a set of 16 and 300$s. Thanks for your time and interest.
Mickeyruder
Sep 2, 2015 02:45 PM
fasteddi
Sep 2, 2015 10:29 AM
SLNTSCPE
Aug 22, 2015 09:15 PM
redmaroz
Aug 16, 2015 11:40 PM
