pushrod length?
Old May 17, 2010 | 04:31 PM
greatskiiiier's Avatar
Car: 98 z28
Engine: ls1
Transmission: t56
Axle/Gears: 12 bolt/ 4.11
pushrod length?
i know the only correct way is to check, but first off, whats the correct way to check? and secondly, is there a common length for this setup?
i have a 72 4bolt main 350 block, deck milled .020 with unmilled 906 vortec heads, seats have been ground and machine work has been done for larger springs, but still speced out to 1.75 install height without any shims
the stock pushrods for the vortec heads are WAY too short, and the stock pushrods for the block with 882 heads are just a little short- and since my calipers only go up to 6" i cant really measure, but they look to be around 7.75" when i put a ruler next to them
tried to give as much info as possible... any ideas?
Old May 17, 2010 | 07:16 PM
shelad's Avatar
Car: 86 Camaro
Transmission: th350 w/2500 stall
Re: pushrod length?
Hi, standard size pushrods for the SBC is 7.800" My set-up is about the same as yours and I went with 8.100" works great.
Old May 17, 2010 | 11:48 PM
TNT_Z28's Avatar
Car: 1987 Camaro Z28
Engine: 355ci, XE262 , 650dp
Transmission: T-5, RAM clutch
Axle/Gears: 3.23 limited slip
Re: pushrod length?
flat tappet cam or retro roller?
Old May 18, 2010 | 02:28 AM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: pushrod length?
Because roller cam pushrods are 7.200
If a stock 7.800 ( for '72 engine ) is short , you need to get a pushrod checker
http://www.summitracing.com/parts/TFS-9001/
so you can buy correct length
Old May 18, 2010 | 09:00 AM
shelad's Avatar
Car: 86 Camaro
Re: pushrod length?
I made the mistake of not getting a pushrod checker. I ended up buying two sets. 8.4 and 8.1 The 8.4 were just long enough that the tips of my rockers hit the valve retainers. Learned my lesson. lol
wigmobile
Feb 26, 2025 02:56 PM
manualbrakes.com
Brakes
63
Apr 9, 2024 11:55 AM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
mfp189
Sep 27, 2015 09:25 AM
Scorched1984
Sep 15, 2015 03:42 PM
