Distributer not level?
Old May 17, 2010 | 10:01 PM
TNT_Z28's Avatar
Car: 1987 Camaro Z28
Engine: 355ci, XE262 , 650dp
Transmission: T-5, RAM clutch
Axle/Gears: 3.23 limited slip
i just installed a new MSD streetfire distributer and when i looked at it closely i noticed that it doesnt sit level. it is higher on the passanger side than the drivers side.
is this something that i should be worried about?
it is definetly seated in the oil pump drive and the cam gear.
Is this normal on sbc's?
this distributer is considerably larger than my old one and maybe thats why i never noticed.
Old May 17, 2010 | 10:25 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Re: Distributer not level?
The cap not seated properly on the body?
Old May 17, 2010 | 10:29 PM
KNBlazer's Avatar
Car: Trailblazer EXT 4.2 (Firebird Form)
Engine: 5.1 4bbl
Transmission: 700R4 Mega Raptor Level 4
well if you say the dizzy is flush on the intake, then the rotor must not be securely attached to the dizzy therefore probably being the reason why your dizzy looks lopsided...
Old May 17, 2010 | 10:52 PM
TNT_Z28's Avatar
i double checked that the cap is on properly, and it sits flush on the intake ill try to post some pics to make it clear.
Old May 17, 2010 | 11:06 PM
Atilla the Fun's Avatar
On Probation
Engine: several
Transmission: none
Axle/Gears: none
I'm eager to see pics, it sounds intriguing.
Old May 17, 2010 | 11:21 PM
TNT_Z28's Avatar
i made an ''album" of some of the pics i cant figure out how to add them to the post. hope that helps
click on my profile and veiw albums
Old May 18, 2010 | 10:21 AM
305sbc's Avatar
Car: 1986 Irocz
Axle/Gears: 3.25:1
The distributor body is aligned by both the block and the intake manifold and cannot bend to any extent.
It's hard to say from just the pics, but it looks to me like the whole engine is tilted a little. If it bugs you take a look at the engine mounts.
Old May 18, 2010 | 10:35 AM
TNT_Z28's Avatar
first off, thank you for all comments and interest
i have checked at multiple points with a level. the top of the intake is square. ive put the level on the dizzy body, rotor, and cap and they are all off. im sure that its seated on the oil pump shaft and the cam gear.
i guess my main point is still unanswered. in small block chevys, does the distributer sit level and and is it cause for concern if it doesnt?
Old May 18, 2010 | 12:17 PM
TNT_Z28's Avatar
i figured it out. i installed my old dizzy and that one sits off square just like the new one and i rocked that one for a year.
Old May 22, 2010 | 06:42 PM
david chambers's Avatar
Car: 1986 iroc Z-28
Engine: "LB-9" TPI 305
Transmission: 700-R-4
Axle/Gears: corporate 2:73-1
ok,so whats a dizzy????
Old May 22, 2010 | 06:44 PM
KNBlazer's Avatar
Engine: 5.1 4bbl
distributor...
Old May 22, 2010 | 09:16 PM
Vader's Avatar
The distributor sits at almost exactly the same angle as the oil pump shaft. Ever wonder why the oil pump is angled? That should explain why the distributor is also angled.
Old May 22, 2010 | 09:20 PM
KNBlazer's Avatar
Engine: 5.1 4bbl
this mean the oil pump is faulty?
Old May 23, 2010 | 12:13 AM
TNT_Z28's Avatar
i hope not. i dont feel llike droppin the pan
Old May 23, 2010 | 12:15 AM
KNBlazer's Avatar
Engine: 5.1 4bbl
that sounds like it be a PITA... I think the engine would have to come out...
Old May 23, 2010 | 09:28 AM
TNT_Z28's Avatar
i drove it for a few months with no oil pump problems. the dizzy gear is seated well in the cam gear and it sits flush on the intake. why wouldnt that be good enough?
also, when i installed the oil pump, the drive shaft seemed to go through a hole in the block that lines it up. i dont understand how that could be "faulty"
and theres no way in hell im takin the motor out already. i just put that f***er in last fall.
Old May 23, 2010 | 09:52 AM
naf's Avatar
naf
Car: 1987 SC/1985 TA
Engine: 350/vortec/fitech
Axle/Gears: 3.27 9-bolt
No. You're over-reading Vader's response. The angle of the dist is determined by the bore in the block and the intake. These bores are lined up with the oil pump shaft. With your dist out you can see that the dist hole is slightly tilted on the intake. The angle is normal-6 degrees if memory serves...
Old May 23, 2010 | 10:38 AM
TNT_Z28's Avatar
THANK YOU NAF!!! that is what i thought he was trying to say. the faulty oil pump comment just threw me off and i just wanted to be sure.
db057
Apr 28, 2019 07:45 AM
Gunner242
Dec 25, 2015 04:49 PM
drptop70ss
Oct 4, 2015 09:44 PM
dusterbd
Sep 29, 2015 08:40 AM
mfp189
Sep 27, 2015 09:25 AM
