Top end setup help :P
Old May 23, 2010 | 09:38 PM
vendetta's Avatar
Car: 1990 Iroc-Z28
Engine: 350HSR
Transmission: HD 700r4 B&M Stage2 SK
hey guys
ive been looking through alot of stuff and have basically come to the topend setup i want with my 90 Iroc, just wanna know some opinions, if stuffs gonna work together ect. let me know what you think!
The Weiand Stealth ram intake (non-vortec)
http://www.jegs.com/i/Weiand/925/7540/10002/-1
Edelbrock Alum. Performer RPM heads
http://www.summitracing.com/parts/EDL-60899/
LT4 Hot cam
https://store.gmperformanceparts.com...umber=24502586
Holley Fuel rails
http://www.holley.com/534-186.asp
Old May 23, 2010 | 09:41 PM
vendetta's Avatar
Car: 1990 Iroc-Z28
Engine: 350HSR
Re: Top end setup help :P
forgot the dizzy, i know you can get the 87+ ones , do they just fit right in?
since mines a 90 wouldnt it already? any suggestions, i dont have a ton of $ to burn but would prefer no junkyard parts.
Old May 25, 2010 | 07:38 PM
vendetta's Avatar
Car: 1990 Iroc-Z28
Engine: 350HSR
anything.... ?
Old May 25, 2010 | 07:57 PM
Atilla the Fun's Avatar
On Probation
Engine: several
Transmission: none
Axle/Gears: none
looks okay to me. Do headers and a cat-back. Get at least a 3.73:1 axle. 4.10 if your car was an LO3 / T5 to start with and you still use that T5. Fifth is taller for the LO3 version than the LB9 version.
Old May 25, 2010 | 08:10 PM
vendetta's Avatar
Car: 1990 Iroc-Z28
Engine: 350HSR
ive already got a magnaflow catback and am still picking headers/ypipe.
and ive got the 700r4
do i have to worry about aluminum heads and intake on a iron block??
Old May 25, 2010 | 09:38 PM
On Probation
Engine: several
Transmission: none
Axle/Gears: none
there's really no cause for concern bolting aluminum heads to your iron block.
Old May 25, 2010 | 10:10 PM
vendetta's Avatar
Car: 1990 Iroc-Z28
Engine: 350HSR
why is it an issue when you have aluminum manifolds and iron heads?
just curious
Old May 25, 2010 | 11:27 PM
On Probation
Engine: several
Transmission: none
Axle/Gears: none
SBCs really don't have any issues with aluminum on iron. All the bugs were worked out decades ago. These days, just use Fel-Pro gaskets and skip the silicone, you're all set.
Old May 27, 2010 | 07:37 PM
vendetta's Avatar
Car: 1990 Iroc-Z28
Engine: 350HSR
any other suggestions on the cam? and what exactly do you need to match up on cams with heads? all i know i the valve lift.
lastly whats this ive seen about 1.6 rockers, what does that do for you?
these any good? http://www.jegs.com/i/Proform/778/66908/10002/-1
thanks a bunch guys! id be no where without the help of my fellow 3rd geners
Old May 27, 2010 | 08:43 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
Dont buy the cam new. You can pick these up used from various LTx forums for cheap. Its a very popular cam and you can save a bunch of money just by finding one used. Rollers dont wear out.
Else get a similar shelf grind from summit racing that you like.
For cam to heads, look at the springs that the heads come with and decide from there if they will work or not. Need to know max lift capability, seat pressure of the spring, and open pressures, as well as spring rate. That will give an idea what control the spring will have over the cam lobe. Hotcam isnt that aggressive so most hyd. roller springs will handle it.
For heads, i dont know too much on the edelbrocks but for same price you have some options. You can have brodix IK180's or 200's which will also do great on that motor with the hotcam. There are others too.
Brodix 180's and 200's are available with comp's 987 springs which are decent hyd. roller springs which will work great for that hotcam.
Not sure of the exact edelbrock specs but they are a 1.44-1.46 spring and i think they are only 100 lbs on the seat which is stock spring like specs. I'd rather see more spring on the roller than that. Dont want float over 5500 rpm where that cam will want to go.
Performer rpms seem to be decent heads just dont know too many setups using them. Advertised in the 240 cfm range, but I have heard edelbrock numbers are usually lower than advertised more so than other companies. Dont have any data to back that up but can look into it. IK180s match them in flow, IK200's are near 260+ range, not great for a 200cc head but the price is nice.
Old May 27, 2010 | 08:59 PM
vendetta's Avatar
Car: 1990 Iroc-Z28
Engine: 350HSR
hmmmm interesting, so youd take that setup just with the brodix heads instead?
they never even came up in my original search for heads, options....sigh lol
Old May 27, 2010 | 09:29 PM
vendetta's Avatar
Car: 1990 Iroc-Z28
Engine: 350HSR
so ive looked at the brodix and im liking them, also say the Patriot Performance Freedom Series 900$/pair!! says theyve got 115lbs/clsd 310/opn for the spings, http://www.jegs.com/i/Patriot+Perfor.../2121/10002/-1
let me know what you think of them, doesnt say if theyre center bolts or anything tho?? thanks for the help
Old May 27, 2010 | 10:27 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
HSR is drilled for both style of heads so no worries there. I dont know much about how the edelbrocks perform but they are probably more than enough head for that setup. Hotcam with supporting bolt ons is usually a 330whp cam on stock LT1 heads which flow about 225cfm. Any of those 180cc heads flowing in the 240 cfm range should pick up another 20whp. 350whp out of a hotcam is doing fairly well. I have seen 380 in a 383 but most 350 stock bottom end cars will make in the 340-350 range with decent heads.
Thats a good street setup that wont be too hard to tune. Its your preference on heads. As long as the springs look good for a hydraulic roller I think it will control the valves just fine. On brodix website, it says 987 springs which were popular with LT1 guys doing cams, same with 986 springs. Both have decent rates for the hotcam. LT4 springs that come in the kit are surprisingly weak at 100lbs on the seat and barely have enough lift room. I know alot of guys dont run them and some do but I'd go with more spring. Since most heads with a dual spring have alot more pressure than 100lbs, I think you will be ok.
Old May 28, 2010 | 10:35 PM
vendetta's Avatar
Car: 1990 Iroc-Z28
Engine: 350HSR
the Brodix 180s or 200s better? i asked a few ppl and theyre saying 180s?
the 200s seemed to just be a step up?
Old May 30, 2010 | 12:40 PM
JakeJr's Avatar
Car: 1996 Vette / 1992 GSX1100F Suzuki
Engine: 1996 Corvette Coupe 388 LT1 (+.060)
Axle/Gears: 3.07
180s are better for a 350 CID engine. Higher air velocity and better throttle response. Better low end torque. I bought Dart 180s for my son's 350 LT1, so I practice what I preach, LOL
Bigger isn't necessarily better.
Jake
Old May 30, 2010 | 01:55 PM
vendetta's Avatar
Car: 1990 Iroc-Z28
Engine: 350HSR
yea, theyre seeming like a good fit for sure. Any suggestions on some rockers while im at it anyone?
Old Jun 1, 2010 | 10:10 AM
vendetta's Avatar
Car: 1990 Iroc-Z28
Engine: 350HSR
also looking at pistons now if anyone wants to shoot me some ideas.
thnx
Old Jun 2, 2010 | 09:20 AM
JakeJr's Avatar
Axle/Gears: 3.07
I run (and recommend) fill-bodies, NSA Scorpions. I'm running them on my 388 and installed them on my son's 96 LT1 last summer. FlatlanderRacing.com $222 last time I checked.
Jake
Old Jun 2, 2010 | 01:10 PM
vendetta's Avatar
Car: 1990 Iroc-Z28
Engine: 350HSR
ill look into those, are there any that are close to just being stock replacements?
i dont think anyones eber been into the engine , if i get it honed just to clean it up a lil am i going to have to use oversized ones?
Old Jun 2, 2010 | 07:09 PM
mvp2ceo's Avatar
Car: 87 IROCZ
Transmission: 700R4 shift kit, corvette servo...
Axle/Gears: 26 spline 4.10 mini spool
Im running jegs 1.6 roller tips in my 87 305 tpi and havent had any problems with them
Old Jun 3, 2010 | 11:44 AM
vendetta's Avatar
Car: 1990 Iroc-Z28
Engine: 350HSR
i just took a look at those and they seem pretty legit, unless theres any cons i think ill probably get those!
ordered my HSR today and am just waiting to hear from my local speed shop about the brodix IK180s
Old Jun 3, 2010 | 10:42 PM
vendetta's Avatar
Car: 1990 Iroc-Z28
Engine: 350HSR
what do you guys think of these Proform aluminum self aligning rockers?
Proform #778-66915C
SB-Chevy Self-Aligning Rockers
For centerbolt valve covers
1.6 ratio, 3/8" stud
160 bucks for the set of 16 seems decent
Old Jun 4, 2010 | 10:24 AM
firebirdfever's Avatar
id look into this for your maniflold has done some great things for me
http://tpis.com/parts/view/33
Old Jun 5, 2010 | 11:02 AM
vendetta's Avatar
Car: 1990 Iroc-Z28
Engine: 350HSR
900$ vs HSR for $375
budgets tight so HSR wins lol
Old Jun 8, 2010 | 10:28 PM
vendetta's Avatar
Car: 1990 Iroc-Z28
Engine: 350HSR
now i had read somewhere on here something about the manifold to cyl head bolts
not lining up just there being 2 different angles they can come in.
took a look at my HSR and its much more angled then my stock( being almost compleatly flat)
customblackbird
Aug 15, 2021 10:16 PM
Terrell351
Jun 13, 2021 01:13 PM
Street Lethal
Apr 30, 2019 12:14 PM
SiCkRs
Members Camaros
32
Jul 1, 2018 04:53 AM
Azrael91966669
25
Jun 20, 2017 04:04 AM
