Couple of questions...
Old May 28, 2010 | 12:41 AM
coocoobird's Avatar
Car: 87 Iroc-z
Engine: 350 5.7
Axle/Gears: 2.73 / Stock
Hey all
Just ran at the 8th mile track here in greer SC and although it was a fun day i had lots of headaches. First my mechanial edelbrock fuel pump seems to be transfering a lot of heat onto the fuel hose and its melting the end of it. Ending up spraying a lot of gas all over. Its regular fuel hose im using for it. Is there high temp line or something? The engine isnt overheating according to my temp gauge and that brings me to my next question.. i had to rig the temp sender end that goes into the head. I switched to vortec heads and on my old stock heads the sender seated perfect and snug. Well on these vortec heads the hole seems a lot deeper cause when i tighten the nut all the way down i can still push the sender farther in the head and it leaks if i dont pull it back. So i just put a little clamp on it to keep pressure on the sender. Seemed to work for now but i would really like something thats gonna fit. That or i could put it into my edelbrock performer intake however the place to put it on the front is to short, go figure.. any suggestions here? Thanks all
Btw way the iroc ran 11.2 first pass which the shift points were way off, a 10.00 on the 2nd which the tranny jumped from 1st to 3rd for some reason (human error? lol) and 9.40 the 3rd run spinning 30 feet down the track.. on steet tires.. was fun though.
Old May 28, 2010 | 01:22 AM
skirkland1980's Avatar
Car: 82 S10, 83 280ZX, 84 Z28
Engine: 355 smallblocks..na, 2.8 turbo
Transmission: 85:th350, 84:700R4
Axle/Gears: 85:ford9 4.85, 84:stock 3.24
Re: Couple of questions...
ive never heard of fuel line melting like that. do you have a pic? if so include a pic of the sender.
Old May 28, 2010 | 01:30 AM
coocoobird's Avatar
Car: 87 Iroc-z
Engine: 350 5.7
The car is at my brothers house so i will try and get a pic of the hose tomorrow but ya its getting crazy hot which ive never seen. The temp guage i have is a cheap sunpro one. I see a lot of senders have 1 solid piece but these dumb sunpros have the little temp sensor on the front with the plug on the back pushing it in the hole. Hell if it was 1 piece i wouldnt have an issue.. i guess ill just go to auto store tomorrow and try and find something that fits in the top of the intake.
Old May 28, 2010 | 01:37 AM
make sure the fuel lines are far away from the exhaust. if its close put some fire blanket around the lines. check the lines all the way from the tank to the carb.
Old May 28, 2010 | 03:11 PM
coocoobird's Avatar
Car: 87 Iroc-z
Engine: 350 5.7
You know heres whats weird.. my fuel pump is located in the same place as the stock one ofcourse but instead of the outlets facing forward they are facing down as i had to put a outlet relocation kit on it for the pump that i got. Well only the outlet hose is melting at the connection to the fuel pump. The one coming from the gas tank is fine.. I was thinking ok maybe the headers are heating up the fuel pump more then usual but if that happened i would think both hoses would melt.. crazy crazy..
F-body-fan
Jan 12, 2023 01:49 PM
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
RedLeader289
May 28, 2019 01:47 PM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
Linson
Oct 1, 2015 09:50 PM
