Removing all electronics
Old May 30, 2010 | 08:18 PM
chcgobearsfan3's Avatar
Car: 90 camaro RS
What's involved? Can the car run well without o2 sensor, ccc q-jet, dist, etc? I'm only getting around 9-10 mpg as it is. Changed plugs, wires, oil, running 2.73s, and a 305.
I've read some topics but I'm unsure of what the TCC lockup function is and why it's needed... other than that, I haven't seen any issue in removing everything and going to non-computer controlled.
Input?
Old May 30, 2010 | 09:41 PM
travis401's Avatar
Car: 91 Camaro RS
Engine: empty bay (for now)
Transmission: Built T-56
Axle/Gears: 3.42 stock posi disc
Re: Removing all electronics
Its not that hard, but time consuming and you gotta buy some new parts. New intake, carb, HEI distrubutor. The TCC lockup is torque converter lockup. Its not NEEDED, but recommended. It keeps the torque converter from slipping while cruising at higher speeds, meaning it gives you better gas mileage on the freeway. After you get the new parts installed, you have to figure out the wiring. You can modify your stock harness correctly to work, but it takes time and effort. There is a thread here that will help a lot.
If youre getting that bad gas mileage with stock components there is something wrong. Id suggest taking it somewhere and getting a full tune up. It would probably wind up being cheaper than replacing things. And if you don't know how to properly tune the new carb, you're not gonna be any better off anyway.
Old May 30, 2010 | 09:46 PM
Car: 90 camaro RS
I figured, but the damn places around here are quoting $500 for a "full" tuneup and I've already done the plugs, wires, rotor, and oil. What all am I missing? I mean the car runs fine, but it gets horse **** mileage even when I lug it at the lowest RPM possible. No more than 1500 on the highways, etc. Driving like an old person in town, too.
Old May 30, 2010 | 11:09 PM
ksith's Avatar
Car: 87 trans am
Engine: 5.7
Transmission: t-5
Axle/Gears: 9 bolt posi 3:27
ive got the same problem i get 11 mpg but i already removed the old 305 and dropped in a 350 with a 4160 holley. seriously considering taking it to a dyno and having them tune it.
Old May 30, 2010 | 11:26 PM
Car: 90 camaro RS
Yeah it sucks, I have a 2000 mile trip to make out to AZ and my 07 escalade with rooftop storage makes better mileage... I want to get this thing up to at least 18 on the highway before I go, but I don't know what the hell's going on with it.. drives great though.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
Nick Locking
Car Audio
Sep 30, 2015 04:24 PM
gta892000
Sep 16, 2015 12:37 AM
FormulasOnly
Sep 10, 2015 09:07 PM
Fronzizzle
Sep 8, 2015 12:10 PM
