What does a damper spring do
Old May 31, 2010 | 06:18 PM
vendetta's Avatar
Car: 1990 Iroc-Z28
Engine: 350HSR
Transmission: HD 700r4 B&M Stage2 SK
hey guys
im looking into getting either some brodixIK180s or Edelbrock performer RPM
heads(60899), and the only real difference between them besides the minor differences in flow is that the Brodix come with damper springs and the eddys dont,
is this a big deal, what exactly do they do
thanks
Old May 31, 2010 | 06:47 PM
Saabster's Avatar
Car: 89 Camaro RS
Engine: LO3 TBI
Transmission: 700R4 => WC T-5
Axle/Gears: 3.42 Open Diff
Re: What does a damper spring do
They're there to control resonance, like all dampers.
Old May 31, 2010 | 06:56 PM
vendetta's Avatar
Car: 1990 Iroc-Z28
Engine: 350HSR
so do they make a big difference, what would be noticed
Old May 31, 2010 | 07:17 PM
Saabster's Avatar
Car: 89 Camaro RS
Engine: LO3 TBI
Didn't say that, but you asked what they were for. Most cars got on fine without them. This wouldn't be the deciding factor on heads for me personally.
Old May 31, 2010 | 07:24 PM
vendetta's Avatar
Car: 1990 Iroc-Z28
Engine: 350HSR
what would you pick out of those 2 heads, just gathering some input
thanks
and p.s. i cant get my new laptop to put question marks ...
Old Jun 1, 2010 | 12:47 PM
JakeJr's Avatar
Car: 1996 Vette / 1992 GSX1100F Suzuki
Engine: 1996 Corvette Coupe 388 LT1 (+.060)
Axle/Gears: 3.07
I'd go Brodix. What are the flow numbers of both?
Jake
Old Jun 1, 2010 | 03:10 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
I don't know why Summit's description says the Edelbrock heads don't have damper springs. I've never seen any single valve spring engine, other than a Briggs & Stratton, that didn't have damper springs.
"Single spring" means it has the main wire coil and a damper inside. "Dual spring" means there is an external wire coil with another wire coil inside it wound in the opposite direction - the two springs dampen out the resonance produced by the other one.
Old Jun 3, 2010 | 11:47 AM
vendetta's Avatar
Car: 1990 Iroc-Z28
Engine: 350HSR
hmm, i think the eddys flow a couple cfm higher all around just havent gotten around to checking again, it was only bout 5cfm difference tops, how much of a difference would that make on the car?
Old Jun 3, 2010 | 06:12 PM
five7kid's Avatar
I'd go with the Brodix, all else being equal.
LT1Formula
Oct 8, 2015 08:34 PM
Galaxie500XL
Oct 1, 2015 01:05 PM
