A/c with carb
Old Jun 5, 2010 | 04:49 PM
travis401's Avatar
Car: 91 Camaro RS
Engine: empty bay (for now)
Transmission: Built T-56
Axle/Gears: 3.42 stock posi disc
A/c with carb
I swapped out my 305 for a bored n stroked carbed 350. I kept my A/C and it works. My question is what have you guys done to solve the RPM drop when you kick on the A/C? Right now Ive got my idle set at 800-900 RPM, but when I kick on the A/C the RPM drops to about 400-500 and then dies. The only way to keep it goin' is to give it a little throttle, which would be impractical while driving. Is there some kind of solenoid out there that bumps up the idle when the A/C is switched on like the stock computer would do? How did older factory non CC carbed cars overcome this?
Old Jun 5, 2010 | 05:24 PM
Awesome-X's Avatar
Car: 87 Camaro
Re: A/c with carb
Good question, I'd like to know the answer to this as well
Old Jun 5, 2010 | 05:27 PM
chevysquid's Avatar
Car: 1986 IROC T-TOP
Transmission: 700-R4
Re: A/c with carb
Remove the A/C!
Old Jun 5, 2010 | 06:19 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
Re: A/c with carb
My 80s Buick is standard carb n AC
Only thing extra on the standard carb I could think of would be the idle stop solinode but that's to stop run on.....
Id have to take a wild guess and say somehow it must turn off the AC below a certain speed but can't test, it was out of air so the belt is long gone.
Unless it used the cruise system to bump it up.
Its a very good question
Old Jun 5, 2010 | 06:20 PM
travis401's Avatar
Car: 91 Camaro RS
Re: A/c with carb
Hell no, I live in Texas, and the temps in summer reach 100+. No way in hell Im going through that with no AC. My truck has no AC its torture driving it in the heat with all 5 windows open.
So far Ive found out that 70s factory A/C cars did have an idle control solenoid to raise the idle speed when the A/C was on. Ive found 2 on ebay for $75-$100. Is there a cheaper solenoid to be had?
Old Jun 5, 2010 | 06:23 PM
travis401's Avatar
Car: 91 Camaro RS
Re: A/c with carb
Ive read countless engine swaps and switching to carb swaps and such. Out of all of them Ive read, Ive never seen anyone mention how they fixed the RPM drop issue with the AC (aside from removing it completely).
Old Jun 5, 2010 | 06:28 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
Re: A/c with carb
Junk yard, 5 finger discount
I was told it was for run on but that also make sense, it must be engerized when the AC is on. Its a 1 wire hook up deal.
Old Jun 5, 2010 | 06:32 PM
travis401's Avatar
Car: 91 Camaro RS
Re: A/c with carb
Thats what I was thinking, but then Id have to fab up a bracket and all that. Im curious to see if there is a kit that solves this problem, but I havent found anything.
Old Jun 5, 2010 | 06:46 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
Re: A/c with carb
depends on the intake, should be ready for it, the bracket is part of the Sol and only held on with 1 bolt.
Old Jun 5, 2010 | 06:47 PM
travis401's Avatar
Car: 91 Camaro RS
Re: A/c with carb
Well for those interested, i just found out Holley sells the bracket, solenoid and nut.
Holley part #s:
Solenoid: 46-74
Bracket: 20-9 (for 4150 & 4160 models)
Nut: 26-57
Old Jun 5, 2010 | 06:51 PM
travis401's Avatar
Car: 91 Camaro RS
Re: A/c with carb
All three can be had from summit for $88.89 before shipping.
Old Jun 5, 2010 | 07:01 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
Re: A/c with carb
check DHR just incase, I just got some Alston SFC there and the beat everyones price, including Alston's, and funny is, they are having Alston drop ship them to me Saved me $40
https://www.dougherbert.com/index.php
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
codeysabatini
Nov 10, 2015 04:07 PM
budowski
Carburetors
Oct 2, 2015 10:16 AM
BLK87Z
Sep 18, 2015 11:29 PM
Mdenz3
Sep 17, 2015 08:36 AM
