86 Z28 Wont Start
Old Jun 11, 2010 | 01:59 PM
veihl's Avatar
86 Z28 Wont Start
My 1986 Z28 Camaro wont start. When the key is put in the ignition it puts on a high pitched buzzing sound, and the starter will crank only once if it cranks at all. The problem may be electrical it looks like my entire car was wired by a drunk man with electrical tape. Any ideas?
Old Jun 11, 2010 | 02:35 PM
built91Z28's Avatar
Car: 1991 Camaro Z28
Engine: 357, Canfield heads, solid roller,
Transmission: Upgraded 03 Cobra T56
Axle/Gears: 9" 3.50 gears and Detroit Locker
Re: 86 Z28 Wont Start
Fist things first. Take the battery out and get it charged at an auto parts store. Then see what happens and write back.
Welcome to the forums BTW.
Old Jun 12, 2010 | 03:00 PM
veihl's Avatar
The battery is less than weak old, and i have already gotten it checked. The battery is fine
Old Jun 12, 2010 | 05:37 PM
built91Z28's Avatar
I would check the battery cables then. Remember the ground is just as important as the power side. Make sure you have good clean connections at the battery and the ground wire where it attaches to the chassis is good and clean.
Frozer!!!
Jan 19, 2024 04:55 PM
jklein337
Sep 19, 2018 06:23 PM
Cleotiz
Jan 6, 2018 08:56 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
Bryan F
Aug 18, 2015 02:28 PM
