350 tbi vs tpi short block?
Old Jun 12, 2010 | 05:42 PM
wannafbody's Avatar
Car: 88 GTA
Axle/Gears: 3.27 9bolt
I blew my tpi and found a rebuilt 350 tbi motor.
I was wondering what is differnt on the tbi short block from the tpi?
Old Jun 12, 2010 | 06:27 PM
Atilla the Fun's Avatar
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Re: 350 tbi vs tpi short block?
the TBI engines didn't get roller lifters, but you can swap all that stuff over. Otherwise, they're functionally identical. Have at it.
Old Jun 12, 2010 | 08:38 PM
wannafbody's Avatar
Car: 88 GTA
what about the pistons? Are the l98 ones better? compression the same?
Old Jun 12, 2010 | 08:45 PM
built91Z28's Avatar
Car: 1991 Camaro Z28
Engine: 357, Canfield heads, solid roller,
Transmission: Upgraded 03 Cobra T56
Axle/Gears: 9" 3.50 gears and Detroit Locker
Are you 100% on that? Not doubting you, just making sure. My GF's 91 RS has a roller short block. We always assumed it was the stock 305 motor, but now I may need to go check what it really is.
Old Jun 12, 2010 | 09:00 PM
On Probation
Engine: several
Transmission: none
Axle/Gears: none
All the '87-up passenger car 305s were roller. All the '88-'95 truck TBI V8s were non-roller. All the '88-up 4.3s were roller. All '87-up blocks will accept stock rollers.
Old Jun 12, 2010 | 09:01 PM
On Probation
Engine: several
Transmission: none
Axle/Gears: none
If it's been rebuilt, then it got new pistons anyway, it's luck-of-the-draw. But to start with, both came with dished pistons. Only 'vettes had flat-tops, and I'm not sure when those stopped.
wannafbody's Avatar
Car: 88 GTA
So would it have the same compression as my l98 if I use my l98 heads?
I just dont wanna lose power at all
Old Jun 12, 2010 | 09:02 PM
On Probation
Engine: several
Transmission: none
Axle/Gears: none
what about the pistons? are they the same?
I just answered that in post #6
Old Jun 13, 2010 | 06:09 AM
thomas1976's Avatar
Car: 91 Trans am
Engine: built 360 TBI
Transmission: built 700r4
Axle/Gears: 10bolt/3.23
You need to find out, cylinder bore, piston to deck, compressed head gasket and piston dish mesures to calculate the compression. The 083 heads should be around 64cc chambers.
http://www.kb-silvolite.com/calc.php?action=comp
91-92 firebird service manual says 9.75:1 CR for the L98.
TGO tech shows 9.3:1 CR for the 88 L98 https://www.thirdgen.org/1988-pontiac-firebird
Old Jun 13, 2010 | 09:24 AM
On Probation
Engine: several
Transmission: none
Axle/Gears: none
9.75:1 was a typo.
And if the TBI short block you're looking at does have dished pistons, then you don't HAVE to do all what Thomas typed, it'll be close enough to safely use on pump premium. When winter arrives, then you can safely experiment with lower octane.
Old Jun 13, 2010 | 01:22 PM
thomas1976's Avatar
Car: 91 Trans am
9.75:1 was a typo.
What would the correct CR be for a 91-92 L98 with flat top pistons, for comparison?
Old Jun 13, 2010 | 03:40 PM
On Probation
Engine: several
Transmission: none
Axle/Gears: none
that's the thing, NO '91-'92 V8 F-cars actually came with flat-tops. 9.25:1 is close enough to precise, a quarter ratio either way has no real impact on choosing a cam for one of these engines. You're still looking at pump premium for over 90% of the possible situations.
xkingcodex
Feb 12, 2020 07:43 PM
Jake_92RS
Jan 28, 2020 10:37 PM
camaro71633
Sep 1, 2015 10:24 AM
lakeffect2
Aug 23, 2015 08:44 AM
BBSDesigns
Aug 11, 2015 07:39 PM
