What motors are roller cam?
Old Jun 14, 2010 | 11:51 PM
Benjam88's Avatar
So are all centerbolt valve cover motors roller cam? Mostly interested in The L05 and the L98.
Old Jun 14, 2010 | 11:58 PM
jstoltz's Avatar
Car: 1987 Iroc-z Convertible
Re: What motors are roller cam?
yes and no. all centerbolt motors that came in third gens were roller motor 87 on up but the centerbolt motors in trucks stayed flat tappet for a little while longer until 91 I believe someone please correct me if I am wrong but to the best of my understanding the information I have given is correct.
Old Jun 15, 2010 | 07:53 AM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
All 1 pce seal ('86+ ) blocks are machined for roller cams but the truck engines had flat tappet cams installed
The truck engine will take all the factory roller cam parts to run a roller cam
Old Jun 15, 2010 | 10:39 AM
JakeJr's Avatar
Car: 1996 Vette / 1992 GSX1100F Suzuki
Engine: 1996 Corvette Coupe 388 LT1 (+.060)
Axle/Gears: 3.07
Vettes are different too. IIRC, Mid 86 Vettes got center bolt heads but kept the flat tappet cam. Early 86 Vettes had perimeter bolt heads and flat tappet cams.
In 87 they got roller cams to go along with thre CB heads.
Jake
Old Jun 15, 2010 | 11:08 AM
jstoltz's Avatar
so I guess the general concensus is that as long as it is a mid 86 on up motor then it will accept rollers not sure if the holes for the spider hold down assembly are there already though. My guess would be no but wouldn't be the first time I was incorrect about something. Hope it helps.
junkcltr
Aug 2, 2019 11:12 PM
MoJoe
Sep 24, 2015 09:12 PM
camaro71633
Sep 1, 2015 10:24 AM
anesthes
Aug 8, 2015 09:37 PM
