Advice on installing shorty headers
Old Jun 20, 2010 | 06:58 PM
ninetyone's Avatar
Car: 91' Firebird SOLD
Engine: 350 TPI +bolt-ons
Axle/Gears: 3:42
Ok, so I found a pair of used shorty headers for cheap. My question is this: They are not "air" headers, so what do I do with the air tubes that go to each of the exhaust manifolds? Should I cut each individual tube or unplug the tube assembly and cap that big tube off? Anyone know? I want to keep air to the converters.
Old Jun 24, 2010 | 02:30 AM
oamhmad's Avatar
Car: 84 Trans AM
Engine: Goodwrench 350 Crate motor
Re: Advice on installing shorty headers
It doesn't matter you can go either way. Even if you don't cap those tubes off nothing bad happens. The air pump will still push air through them and out into the engine bay. Once the engine heats up the air will still divert to the cat. If you don't care about emissions just remove the entire air system and make changing spark plus simpler.
Reddeath210
Oct 6, 2015 08:20 AM
djmarch
Aug 19, 2015 12:07 PM
formula_novice
Aug 18, 2015 08:48 PM
IROCThe5.7L
Aug 10, 2015 11:24 AM
mustangman65_79
Aug 7, 2015 09:55 PM
