Performance chips do they work?
Old Jun 22, 2010 | 09:34 PM
'87IROCZOWNER69's Avatar
Car: 1987 IROC-Z and 1988 Iroc-Z
Engine: 5.7 350 V8 and 5.0 305 V8
Transmission: 700R4 Automatic Transmission
Axle/Gears: 3.27 Posi
I have always wanted to add more horsepower to my car but have not wanted to spend much money and wanted it to be something that I could easily remove if I sell it one day (which probably wont happen). Then I came upon this http://www.autoaccessoriesgarage.com...rformance-Chip I was curious if these actually work. Also I was wondering if they can screw your car up. Does anyone have any answers to these quetions?
Old Jun 22, 2010 | 09:37 PM
RyanEricW's Avatar
Re: Performance chips do they work?
For some reason the link you posted, send me to "2007 BMW 335i Exhaust System - Borla - Split Rear, Stainless steel" Lol...might want to fix that if it is an error of yours =)
Old Jun 22, 2010 | 09:58 PM
That should work now.
Old Jun 22, 2010 | 10:01 PM
juanillox8's Avatar
Car: TOO MANY
Engine: 350 TPI / 350 TBI/6.0L VORTEC
Transmission: T5/AUTO/AUTO
nope is not fixed
Old Jun 22, 2010 | 10:04 PM
now try
Old Jun 22, 2010 | 10:10 PM
juanillox8's Avatar
Car: TOO MANY
ok.. yes they do work but it works in conjunction with whatever you have in ur car for example if you have headers a mild cam exhaust u need a performance chip in order to get the most out of your performance parts, one thing alone doesn't add that much hp to ur car, also u need to use 91 octane gas or equivalent in ur state.
Old Jun 22, 2010 | 11:14 PM
Do you have to use the high octane gas or will it still work on regular unleaded but not as well. As far as I know my car has no aftermarket parts and I cant afford to use high octane gas.
Old Jun 22, 2010 | 11:17 PM
juanillox8's Avatar
Car: TOO MANY
it runs shitty without it, with the ones i've used u need the high octane... at least I have seen a difference when using a lower octane
Old Jun 22, 2010 | 11:35 PM
How much horsepower would it add if I used 87 gas. And how much would it add if i used 91 gas. Thanks
Old Jun 23, 2010 | 03:20 AM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Originally Posted by juanillox8
ok.. yes they do work .
Do a search , most will say all they do is lighten your wallet.
None of the off the shelf chips do anything for the cost
https://www.thirdgen.org/forums/tpi/...-also-tps.html
https://www.thirdgen.org/forums/tpi/...hip-stage.html
Old Jun 23, 2010 | 03:40 AM
stealthroc89's Avatar
Car: 1989 IROC-Z
Engine: 355, 6.0 (LQ4) soon
Axle/Gears: Borg Warner 2.77 for now
They work ok for a car with some bolt-on parts, but you have to wonder how much power comes from the octane increase. All they really do is modify the ignition tables which is why you need the extra octane, to ward off detonation from the increased timing.
Old Jun 23, 2010 | 07:36 AM
DIRTY JERZY's Avatar
Car: 89 formula 350 & 2001 ws6 ta
Engine: 350 tpi & ls1
Transmission: 700r4, t56
Axle/Gears: 9 bolt ? & 10 bolt 3:42
How big of a cost increase is preimium over regular per fill 2 or 3 dollars?
Old Jun 23, 2010 | 07:54 AM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
Originally Posted by stealthroc89
They work ok for a car with some bolt-on parts, .. All they really do is modify the ignition tables which is why you need the extra octane, to ward off detonation from the increased timing.
Which is why for the $$ you are better off getting a custom mail order tune tailored to your car; not a one size fits all chip
Old Jun 23, 2010 | 08:00 AM
92firebird 305's Avatar
Car: 1992 pontiac firebird
Engine: 305 v8 lo3 201.5hp and 268.2 tq
Transmission: 4speed 700r4 corvette servo
Axle/Gears: 3.42 disk posi 4th gen rear swap
HI i got a chip from here for 110 shipped to my house it is told to give you 17 hp and 20 pounds of tork http://tbichips.com/305mods.htm i have to use 93 octane gas i get better mpgs to it seems
Old Jun 23, 2010 | 09:31 AM
juanillox8's Avatar
Car: TOO MANY
im only speaking by personal experiences and i did mention they work if you have other performance parts... for example if you install a cold air intake or throttle body spacer and stuff like that to increase the air flow to the engine you also have to use a less restricted exhaust system otherwise you wont really see an increase on performance...
I do agree with you that some chips do do shhh*** specially from ebay lol
Old Jun 23, 2010 | 12:23 PM
So it sounds like most of you are saying it is better to save the money up for something else like a cold air intake or some other bolt on parts then.
Old Jun 23, 2010 | 12:39 PM
ntomsheck's Avatar
Car: 1989 GTA
Engine: 350TPI w/ Speed Density
Axle/Gears: Borg warner 3.27
Lol or exhaust - headers back. CAIs are garbage for our car unless you make it yourself. The stock camaro intake tube is one of the least restrictive parts compared to exh manifolds, heads, etc etc. Headers you'll notice a difference in the seat of your pants.
Old Jun 23, 2010 | 01:53 PM
juanillox8's Avatar
Car: TOO MANY
lol i agree...
'87IROCZOWNER69 u misunderstood the cold ar intake part i was just using it as an example of parts working together, but yea its hard to get noticeable power increase without putting money and bolt on parts in our cars.
Old Jun 23, 2010 | 08:51 PM
So everyone agrees I should save the money for some headers and a full exhaust system then.
Old Jun 23, 2010 | 11:26 PM
ntomsheck's Avatar
Car: 1989 GTA
Yep. Read around these forums and find your ideal header size. When swapping them, you'll immediately notice a difference between these iron exhaust manifolds and whatever header set you buy. The ports, the interior dimensions, the weight.
Old Jun 23, 2010 | 11:59 PM
Lasalt's Avatar
Car: 1991 Pontiac GTA
Engine: 5.7 350
Transmission: Automatic
What is a good set of headers to use on a 91 GTA?
Old Jun 24, 2010 | 01:01 AM
Stangski09's Avatar
Car: 1988 Pontiac Trans Am GTA.
Engine: 385 stroker sbc
Transmission: TKO600
Axle/Gears: Moser 9" 3.70 Wavetrac
Hooker 2055s are good, come with a nice ypipe as well. Or Dyno Dons from Top Down Solutions too. Just use the search bar man
Old Jun 24, 2010 | 12:09 PM
What would one of you recommend for my 87 IROC 5.7l 350?
Old Jun 24, 2010 | 05:14 PM
ntomsheck's Avatar
Car: 1989 GTA
All headers for thirdgens fit both 305 and 350 engines, 82 to 92. Like someone recommended above, the hooker 2055's are great (one of the best shorty header kits). If you don't mind extra work, you could also go super-comp long tubes (hooker 2210s) which is the direction I'm currently traveling. Use search bar.
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
Reddeath210
Oct 6, 2015 08:20 AM
NBrehm
Aug 25, 2015 11:49 PM
1989formula5.7l
Aug 15, 2015 11:35 AM
