Engine running rich Please help
Old Jun 24, 2010 | 05:19 PM
GusbZConv's Avatar
Ok this car is driving me crazy! I had the car in the body shop for nearly 2 years and it ran great before putting it there. After I got it back the car runs like crap! I have replaced the distributor, fuel injectors, plugs, and fuel filter. It runs better now, but it is still smokes and has the bad odor of fuel. I am not getting any codes and the car idles ok (slight stumble now and then) and revs fine. I checked the fuel pressure and its right on the money. The only odd thing I can find is the fact that the timing mark jumps from 6 to 12 when it is revved up (the ecm was disabled with the tan wire), and then returns to 6 when you let off the accerator. the engine is a 305 TPI with 62k miles on it. Any suggestions?
Old Jun 24, 2010 | 05:38 PM
ntomsheck's Avatar
Car: 1989 GTA
Engine: 350TPI w/ Speed Density
Axle/Gears: Borg warner 3.27
Re: Engine running rich Please help
Check for FPR leaks, bad MAF/MAP sensor, bad IAT, bad TPS, bad O2 sensor. The unfortunate part of OBDI is it will rarely tell you when you car is slightly off base. It only throws codes if a sensor or device is almost completely not working. I would recommend a scan tool or a datalogging cable and laptop - then you can see the real values of your sensors and can pinpoint which item is messing you up.
As for the distributor - someone more wise will have to verify (or deny) this: I think, even with the ESC disabled, the distributor will still advance itself as it gets to the higher RPMs just to keep the engine running/prevent damage.
Please also provide us with the year of your car (or ECM system, if you switched it).
Old Jun 24, 2010 | 05:59 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
It's "limp home mode", and it only advances minimally for a given RPM.
Old Jun 24, 2010 | 06:49 PM
ntomsheck's Avatar
Car: 1989 GTA
I knew it haha. Are you saying it wont advance it from 6 to 12* though?
Old Jun 24, 2010 | 07:42 PM
five7kid's Avatar
No, I'm saying that's about what it does.
Old Jun 25, 2010 | 12:30 AM
ntomsheck's Avatar
Car: 1989 GTA
Ah okay, well there's your explanation for the timing, Gusb.
Old Jun 25, 2010 | 08:05 AM
GusbZConv's Avatar
Checked for vac leaks and found none. Looks like the local parts store is going to love me as I dont have a the capabilities to perform the datalogging. I will keep you posted and let you know what I find.
Old Jun 26, 2010 | 12:32 PM
87IROC-DAN61's Avatar
Car: White 1987 IROC-Z
Engine: 305 TPI LB9, 215 HP
Transmission: Borg-Warner T5 NWC
Axle/Gears: Borg-Warner 7.75 with 3.27 ratio
Hello GusbZConv!!
The HEI module has a built in spark advance, for use during the "Limp Home Mode"
Check your CTS (Coolant Temperature Sensor) to see if it's out of phase, this will give you rich running/higher idle!!
Old Jun 26, 2010 | 09:57 PM
GusbZConv's Avatar
87Iroc-Dan61 thanks for the replay - that might make since it seems to not smoke on start up and really stinks when warm. Today I adjusted the TPS and checked the IAC with no luck. Car seems to not want to start on the first try, but once it starts it runs fine, other than it runs really rich??? Next things on my list to check is the coolant temp sensor and the O2. I will keep you posted on my progress!
Old Jul 2, 2010 | 10:16 PM
GusbZConv's Avatar
Guys thanks for the help, but after many hours of work on this car and many $$$ I AND my finace nave come to the conclusion we will NEVER own another Chevrolet product ever again! I have always owned Ford products and in fact I have a 2007 F-150 and a 2006 Fusion in my drive as I type this message. I HAVE NEVER HAD A MAJOR PROBLEM OUT OF MY FORDS AND WITH THIS ISSUE I AM DONE WITH CHEVY. Good luck to you all. The car is for sale: 1989 Camaro convertible all original with 62000k on it. I bought it from the original owners and restored it. I have many hours into it and Is has alot of new parts. Interior is mint. I am aking $12000 OBO - pics included
Attached Thumbnails Engine running rich Please help-picture-158.jpg   Engine running rich Please help-picture-166.jpg   Engine running rich Please help-picture-167.jpg
Old Jul 2, 2010 | 10:22 PM
Slow Down's Avatar
you said the F-word! I will give you $120.00 for your broken chevy. =
Old Jul 3, 2010 | 08:04 PM
shep236's Avatar
Car: '91 formula 5 speed
Engine: 5 oh
Transmission: manual T5
Axle/Gears: 3:43
wow your 4 year old fords are running good, yeah dude damn gm an there faulty 20+ year old cars we got an love, psshhh why would you even bring up your 06 car dude
Old Jul 5, 2010 | 09:33 AM
game1939's Avatar
Car: 91 chevy camaro
Engine: 383
Transmission: 700r4 built with corvette servo
Axle/Gears: posi 3:73
my 20 year old lugnuts got more torque than both his new fords put together
Old Aug 27, 2010 | 09:13 AM
pwillis3's Avatar
Car: 1987 IROC Z28 Camaro
Engine: Stock 305 tpi
Transmission: 5 speed manual
Axle/Gears: 3.08 posi
You need to understand, these cars are like females. They have many very sensitive parts which must all be tuned and adjusted with care. One wrong move and it may never run right. But, with much patience and care, they can very satisfying. A Ford, on the other hand, just has a simple on/off switch, much like a male.
Old Aug 27, 2010 | 09:25 AM
GusbZConv's Avatar
You can stick your 20 year old lug nuts up your ****ing *** ********!
Old Aug 27, 2010 | 09:27 AM
GusbZConv's Avatar
Yeah, I agree with you they are like females , bitches that is, Car is sold (thank God) and I dont have to deal with you white trash losers no more!
Old Aug 27, 2010 | 09:33 AM
pwillis3's Avatar
You don't deserve to be a ThirdGen member. Go find a Ford forum to throw around your insults.
Old Aug 27, 2010 | 08:51 PM
shep236's Avatar
Engine: 5 oh
Axle/Gears: 3:43
white trash huh, is that why you bought one originally lmao suck my di#k dude
Old Aug 27, 2010 | 08:58 PM
shep236's Avatar
Engine: 5 oh
Axle/Gears: 3:43
he private messaged me this
Hey Shep **** YOU *******! I have had a 69 Mustang anf a 77, 87 with NO problems out of them. Just admit it Chevys are junk. Now you can take your ****ing 2 cents and stick it up your *** mother ****er!
and then i tried to reply but his bitch *** blocked me
MustangBeater20
Oct 29, 2022 09:20 PM
Vintageracer
Jan 10, 2020 05:33 PM
theshackle
Mar 5, 2017 06:37 PM
Jae992
Aug 27, 2015 09:07 AM
squiggy2
Aug 9, 2015 09:30 PM
