Bigger Crank = less Mileage
Old Jun 27, 2010 | 10:24 AM
MikeSammy's Avatar
Car: 1986 Pontiac Firebird
Engine: 357ci 400hp 4BBL
I figured since this is the racing board that maybe some members have put a scat 3.75 stroker crank into their 350 engine. My question related to the gas mileage that you get from putting a bigger crank in. Does the Mileage really go down alot. I heard in the past that a 350 bored .030 got 15 mpg then with the bigger crank to make it a 383 it only got 9 mpg. Is this true? thanks!
Old Jun 27, 2010 | 11:14 AM
RED86Z28's Avatar
Car: 1986 IROC
Engine: 355" TPI
Re: Bigger Crank = less Mileage
If you changed nothing but the stroke of an engine you would increase the fuel required for operation to feed the extra cubic inches. The crank alone would not drop it by 6 mpg though.
Old Jun 27, 2010 | 12:14 PM
ntomsheck's Avatar
Car: 1989 GTA
Engine: 350TPI w/ Speed Density
Axle/Gears: Borg warner 3.27
Everything is all relative. The engine may be sucking in more fuel, but it's also putting out more power, which means less opened throttle blades at PT cruising, which can translate to increased gas mileage. Don't always expect drops, and don't always expect gains.
Old Jun 27, 2010 | 12:21 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
Fuel Economy, Engine Efficiency & Power
http://www.viragotech.com/fixit/Fuel...encyPower.html
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
MM2Robinson
Oct 1, 2017 09:16 AM
djmarch
May 8, 2016 11:32 AM
plm99
Southern California Area
Nov 16, 2015 05:21 PM
Saxondale
Carburetors
33
Oct 1, 2015 10:26 AM
