Click,click,click then start.
Old Jun 29, 2010 | 08:02 AM
Shane B's Avatar
Car: 92 RS
Engine: 5.slow
Transmission: 5speed
Ok,every once in awhile,when I turn the key,it will click,like its a bad starter or solenoid,but after 5-10 clicks it will start.I changed the starter,which came with a new solenoid,and it still does it.I have an idea of where to go from here(ignition swich,bad ground)the battery is less than a year old,Im thinking if it was the batt,the car wouldnt start period.What do you guys think.
Old Jun 29, 2010 | 12:21 PM
'87IROCZOWNER69's Avatar
Car: 1987 IROC-Z and 1988 Iroc-Z
Engine: 5.7 350 V8 and 5.0 305 V8
Transmission: 700R4 Automatic Transmission
Axle/Gears: 3.27 Posi
Re: Click,click,click then start.
THs same thing was happening to my backup car where it would click and stuff but wouldnt start. The thing is the battery had just been replaced less than a year ago. Then one day we borrowed our neighbors battery charger and let it sit for a half hour or so. When we came back we unhooked the cables got in and tried to start it. When we tried the car made a sound like it was tying to start but it wasnt a clicking and after about 5 seconds it started right up. So if I were you I would try that. I think you can get a charger for about 30-50 dollars at walmart or some place like that. I dont gurantee my advice will work so follow at your own risk.
Old Jun 29, 2010 | 09:54 PM
camarorsssss's Avatar
Car: 1991 camaro rs convertible
Engine: Built ls1
Axle/Gears: 3:42
https://www.thirdgen.org/forums/tech...-starting.html
Read this thread, it should have evey possible solution for you problem. my problem turned out to be a bad wire from the solenoid to the NSS and it was the same exact symptoms. goodluck
Old Jun 30, 2010 | 09:14 AM
91350rs's Avatar
Car: 91 camaro RS
Engine: superchargered 350
Transmission: t56
Axle/Gears: 4.10
I had a problem kind of like that. My solenoid wire wasn't tighten down all the... it was a easy fix for me. Might be something to look at
Old Jun 30, 2010 | 10:14 AM
HawkZ28's Avatar
Car: 86 Z28
Engine: Built 312
Axle/Gears: 10 bolt 3.42
I had a similar problem at one time. Turned out to be a bad ground connection to the battery.
Old Jun 30, 2010 | 10:27 AM
ternandes's Avatar
Car: 88 GTA
Transmission: WC T5
Axle/Gears: BW 9-bolt 3.27 posi
It sounds a lot like a loose or dirty electrical connection to me. First, check your battery terminals and cable ends. Make sure they are clean and tight. Then check the connections at the other ends of the battery cables. If it's a bad connection, it will likely be in those areas.
Old Jun 30, 2010 | 03:19 PM
Shane B's Avatar
Car: 92 RS
Engine: 5.slow
Thanks everybody.
RS Reaper
Oct 17, 2018 07:52 PM
Spyder_TheGamer
Oct 2, 2015 12:25 PM
Linson
Oct 1, 2015 09:50 PM
Jlanz55
Sep 29, 2015 08:55 AM
