brief knocking noise on start up
Old Jun 29, 2010 | 11:53 PM
musclecar70sfan's Avatar
Car: 91 Trans Am 'vert
Engine: LB9
Axle/Gears: 3.45 9 bolt
Hey guys, I have a 91 Trans Am with the LB9 (305 TPI) engine that makes a very brief knocking noise on start up. It does this only when the engine is completely cold. The noise lasts for about a second tops and the engine runs fine with no smoke. It has 102,000 miles. I'm thinking it's piston slap but I thought I'd ask for piece of mind. Anything to worry about? Thanks!
Old Jun 30, 2010 | 10:14 AM
one92rs's Avatar
Car: SOLD!!!!!
Re: brief knocking noise on start up
my lil 305 does the same thing. not sure if it piston slap on mine or something else.
Old Jun 30, 2010 | 12:16 PM
LS4GXP's Avatar
Car: 87 Z28
Engine: AFR 383
Axle/Gears: 4:11
so the sound goes away when it warms up, sounds to me its a lifter tap. pull valve cover and adjust
Old Jun 30, 2010 | 12:21 PM
one92rs's Avatar
Car: SOLD!!!!!
mines a deeper noise than the lifter tap.
Old Jun 30, 2010 | 01:11 PM
JTNKTZ's Avatar
Car: 1991 Camaro RS/1989 Vert RS
Engine: 355/350
Transmission: T-5/T-5
Axle/Gears: BW9bolt3.45posi/3.23 Posi
my 350 does this as well, interested to see what some people say. My dad says its normal...
Old Jun 30, 2010 | 01:20 PM
Engine: LB9
Well the thing is it only makes that noise for a half second tops following startup, and that's after the car has been sitting at least overnight. I don't think the engine has much time to warm up in 1/2 a second. And it sounds a little deeper than valve noise, it sounds almost like a light rod knock. But again, it disappears as quickly as it comes.
Old Jun 30, 2010 | 04:31 PM
Dougs91's Avatar
Car: 91 Camaro
Axle/Gears: 3.23 limited slip from 91 Z28
Sounds like an oil pressure issue. Rod bearings may be worn enough to cause the brief knock until your oil pressure builds up. You could try a heavier oil. But it's probably nothing to freak out about just keep an eye on it as well as your oil level.
Old Jun 30, 2010 | 05:38 PM
one92rs's Avatar
Car: SOLD!!!!!
i actually tried a thicker oil and it was worse. actually you want an oil that gets to bearings quicker.
theshackle
Sep 17, 2020 08:26 AM
Orr89RocZ
Apr 25, 2016 08:28 AM
bamaboy0323
Sep 3, 2015 06:07 AM
B_Dubya
Aug 26, 2015 05:09 PM
db057
Aug 22, 2015 08:17 PM
