Buying this longblock for $500 casting #10066036
Old Jun 29, 2010 | 01:54 PM
hydrolic144's Avatar
Car: 1987 GTA Trans Am
Axle/Gears: Borg Warner 9-Bolt 3.27
I made another posting asking about the heads. But I was offered this block for $500. It's a Goodwrench over the counter crate 350 from what I understand. Nothing special about it. Nothing internal done. Believe it's a '86 block. Doesn't come with a balancer, any pulleys, no intake or distributor, headers, blah blah. Basically I have EVERYTHING I'd need to get it going, except for a harmonic balancer. Engine is said to have less than 20k miles.
Anyway, you guys think it's worth $500?
Old Jun 29, 2010 | 02:19 PM
rs owner's Avatar
Car: 89 rs black
Engine: 305 v8 tbi
Transmission: 700r4 stock
Re: Buying this longblock for $500 casting #10066036
no. 1 do you trust the person selling and does he have a warranty aka documentation. a stock 350 engine I guess it depends on what your doing with it. leaving it roughly stock will save you some money but if hotrodding is your thing then you might invest in a short block since you would still have to buy everything else that you want on it. sometimes upgrading the bottom end to handle the power you want to make can cost alot more money than just building that way from the start. It's a nice engine if the mileage is true then IMO it's worth every penny, But if I was going to rawhide then stock won't do.
Old Jun 29, 2010 | 02:24 PM
Atilla the Fun's Avatar
On Probation
Engine: several
Transmission: none
Axle/Gears: none
I wouldn't pay that unless I could pull both heads, the oil pan, and check ALL the bearings. As in, remove ALL the caps. If everything checks out, then it's a good deal. The intake manifold is crap and only worth the scrap value of aluminum.
I wouldn't bother pulling the timing cover, because I'd buy a new cam and timing set to go along with my head porting and better valves.
Old Jun 29, 2010 | 09:00 PM
Went to check it out and end of the day bought it. The block is definitely low mileage, and was definitely kept up with. Almost still looks brand new. I told the guy to keep the intake. I have a Holley of my own that I plan to use.
I don't have any future plans to make this into a beast or power hog or anything. I was solely looking for something to pick up, throw mt bolt-ons on, and cruise.
So for the price I think I did pretty good, got a engine stand as well
Old Jun 29, 2010 | 09:41 PM
Dustytrix's Avatar
Car: 1990 Iroc
Engine: 6.0
Transmission: 4l65E
Axle/Gears: 373 zexel torsen
You might want to use the advice about checking that Atilla gave. I bought one with low miles, clean, ext. Ran it about 3 months without checking anything upfront. Then it smoked like a smog truck, Bad valve guides. But I would not listen to advice given to me,, I hope you do.
Old Jul 6, 2010 | 05:47 AM
rs owner's Avatar
Car: 89 rs black
Engine: 305 v8 tbi
great answer!!!!! you've bought it now o you may as well make sure it doesn't have any probs or if it does you can get them fixed now instead of later.
Old Jul 7, 2010 | 01:06 AM
Guess I didn't update this.
Bought it, and opened up the oil pan. Found a broken piston skirt and metal shavings EVERYWHERE. The guy was clueless. He knew what was up with that thing. And not only that he tried to sell it after the fact to a buddy of mine.
It's a shame how shady people are these days.
On the UP side, bought a 87 non-roller 357 complete for $450. Got it down to the block and it definitely needed head gaskets. It had steel ones but it sat for about a year so gaskets are due now anyway. Engine turns over fine, heads look good, block looks fresh. Lets see where this one takes me.
manualbrakes.com
Brakes
63
Apr 9, 2024 11:55 AM
Mdenz3
LSX and LTX Parts
Dec 10, 2015 11:18 AM
thejimsterz28
Sep 15, 2015 04:37 PM
355tpipickup
Sep 13, 2015 11:35 PM
abray1
Sep 10, 2015 04:53 PM
