alternator squeling
Old Jul 9, 2010 | 08:00 PM
87TAGTA66's Avatar
Car: 1987 Trans Am GTA
Engine: 5.7 TPI
Axle/Gears: Stock 3.23's
alternator squeling
well the belt obviously. i replaced the alternator about 4 weeks ago and since then the belt squels for a few seconds on startup then goes away and its fine til i stop and start the car back up. i figure either i have the belt too tight or loose. when i put the alternator on i put it on as tight as i could with a cheater bar while i tightened the bolts. is there an easy way to adjust the belt without loosening the alternator bolts or is that pretty much the only way??
Old Jul 12, 2010 | 09:17 AM
Aaron R.'s Avatar
Car: 1985 Z28
Engine: 305 LG4
Re: alternator squeling
Pretty much the only way. Sometimes it helps to have a buddy hold it tight with a pry bar while you tighten the bolts.
Old Jul 12, 2010 | 09:21 AM
Twin_Turbo's Avatar
The easiest way is to buy one of those cheap aluminum alternator mount w/ a turnbuckle style adjuster.
Old Jul 12, 2010 | 09:25 AM
86NiteRider's Avatar
From: Somewhere around the South Side of Chicago just crusin' in one of the Niteriders
Car: 92RS 25th Anniv./88 IROC Z28 Vert
Engine: 305 TBI w/Tpi Air / 305 TPI
Transmission: 700r4/700r4
Axle/Gears: Posi
Two things I do is hold a bar of soap on the belt while it is running for a few seconds. This will lub the belt, especially if it is new. I will shoota some WD40 on the center bolt on all of my pully's, air, water pump, crank, etc. I like my belts tight so I won't loosen it up to get rid of n
RS Reaper
Oct 17, 2018 07:52 PM
apie2546
Oct 16, 2016 02:24 PM
SRKLEGIN
Oct 3, 2015 10:11 PM
RS Reaper
Sep 27, 2015 07:04 PM
raymondandretti
Sep 27, 2015 06:43 PM
