Water neck bolt broke in intake man
Old Jul 10, 2010 | 06:53 PM
BigBadGTA's Avatar
Car: 1988 Trans Am GTA
Engine: 350TPI
Axle/Gears: 3:27
I was trying to change my thermostat and the bolt on the right side snapped right off, now I don't know what the **** to do. Coolant is leaking out and I need the car on Monday. I didn't take the water neck all the way off but I see there are threads sticking out of the intake manifold a little bit. Advice? If I took it to a machine shop would they be able to get it out?
Old Jul 10, 2010 | 07:01 PM
86 LT1's Avatar
Re: Water neck bolt broke in intake man
take the water neck off and try and get vise grips on it
Old Jul 10, 2010 | 07:14 PM
jj74sd455's Avatar
Car: 91 bird
Engine: 305 tbi
Transmission: 4 speed automatic
Axle/Gears: factory
when i have bolts break off and there is a 1/2 inch or so of bolt left, i take a stud installer/remover tool on them. i bought mine from a parts store for about 30 bucks. a machine shop could get it out for you but you would have to remove the intake. you could also try to drill it and easy out it. good luck
Old Jul 10, 2010 | 07:20 PM
BigBadGTA's Avatar
Engine: 350TPI
Axle/Gears: 3:27
I highly doubt that I will be able to get it out with some vice grips. It was super tight and I was just barley starting to budge it with a breaker bar. Is there something cheap I can use to loosen it up? Is PB blaster any good?
Old Jul 10, 2010 | 07:42 PM
jay173's Avatar
Not really I had to take an impact to a big intake bolt today and someone put it in sideways so I had to impact it out and took a few threads with it of cast iron block. Normally you have to drill and tap it.
If you have a drill you can be carful and drill on it until the bolt crumbles or you can pull the peaces out. You then would check the threads and if to many are gone you would have to helicoil it.
Hopefully it comes right out somehow.
Old Jul 10, 2010 | 08:44 PM
BigBadGTA's Avatar
Engine: 350TPI
Axle/Gears: 3:27
Damnit I really hope so, I don't have any cash to throw around right now If I cant get it out the car is going to sit. I will take off the water neck tomorrow and see if I can get the damn thing out. If the other one breaks I will be royally ****ed.
Old Jul 10, 2010 | 08:51 PM
Killert's Avatar
Car: 88 Firebird.
Engine: 383 HSR
Axle/Gears: 9 Bolt, 3.27:1 Diskbrakes
Put a nut on whats left of the bolt sticking out, then weld it on. Then just take a socket to it.
Old Jul 10, 2010 | 09:55 PM
jay173's Avatar
not everyone has a welder
Old Jul 10, 2010 | 10:12 PM
Killert's Avatar
Car: 88 Firebird.
Engine: 383 HSR
Try JB Weld, or another good epoxy?
Or if there is a decent amount of stud, put two nuts on it and use a wrench to spin the bottom nut, but I don't think there would be that much stud.
evilstuie
Jan 9, 2020 08:29 PM
LT1Formula
20
Nov 14, 2015 12:02 AM
1985chevydude
Aug 22, 2015 05:36 AM
Dialed_In
Aug 20, 2015 01:45 PM
