what heads are best??
Car: 87 iroc-z
Engine: B2L
Transmission: 700-R4
Axle/Gears: 3:27
i got an 88 iroc B2L i got a flowmaster exhaustmsd 6al jegs distributer accel cap and rotor i self ported and nife edged the plenum runners and base bbk 52mm throttle body and 24lb injectors k&n drop ins and hallowed cat blah blah i was thinkin a set of L31s would be a bad *** set of heads sence there saposed to be the best flowing stock gm head ever built from what ive herd but i wanna get a second opion b4 i go junk yard shoppin for a pair to re do. i wanna know what head would kick the most *** on my car? im not lookin to spend 9000 on a set of after market heads lol i want stock gm bad *** **** plus i dont make good money now and i really wanna spank my buds 87 lx runing 13.28 best so let me know what ya think thanks
Car: '86 Z28, '91 RS
Engine: 305ci, 305ci
Transmission: TH200c (no kidding), TH700r4
Axle/Gears: 2.73, 2.73
Re: what heads are best??
i got an 88 iroc B2L .
i got a flowmaster exhaustmsd 6al, jegs distributer, accel cap, and rotor.
i self ported and nife edged the plenum, runners, and base.
On Probation
Engine: several
Transmission: none
Axle/Gears: none
For running a 13.28 from a B2l, the Vortec heads will get you there, but will require you to change the lower intake manifold. Plus used heads may need a trip to the machine shop, and after all that, you'd be worse off, both results and money, than if you just go buy a set of these: http://www.competitionproducts.com/P...fo/223400080A/ and add a set of these: http://www.competitionproducts.com/S...ductinfo/8440/
On Probation
Engine: several
Transmission: none
Axle/Gears: none
1 piece construction, less weight, much better flow, less wear, better heat management.
Car: 87 IROC-Z28
Engine: 305 TPI-New 355 on the engine stand
Axle/Gears: 3.73 Eaton posi-Soon a 9" Ford!
I already have a set of votrec's from scoggings dickey, but I found these on ebay the other day. Not sure of the quality, but the yare vortecs and a great price.
http://cgi.ebay.com/ebaymotors/ws/eB...K%3AMEWAX%3AIT
http://www.cgmmotorsports.com/sbcalu...ortecrace.aspx
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Those CGM heads are crap. The low-lift intake flow is far short of what it should be, and the exhaust flow is extremely poor in the mid and upper lifts. Plus the upper-lift intake flow is about right for a 1.94"-valved 170cc port, not a 200 cc 2.02"-valved port. These may actually be worse than GM's own "Fast-Burn" heads.
Car: 1992 Camaro RS
Axle/Gears: 9-bolt 3.70
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Consider that Edelbrock's E-Tec 200 heads were developed because of the fast burn heads. Edelbrock found 10% more intake flow with 10cc smaller intake ports. Exhaust flow improved 17%.
Comparing fast burn versus truck Vortec, the high lift flow isn't any better, either. Let's look at mid-lift: The FB is 173 cfm, versus the truck's 190. Up at a realistic 0.475", the truck is 239 cfm, versus the fast burn at under 230.
Less flow from larger ports and valves is bull droppings.
And unless you're well over 400 cubes, you'd do better with 180cc heads anyway.
Car: 87 iroc-z
Engine: B2L
Axle/Gears: 3:27
soo your sayin the votec is the head to use?? cuz i know i gotta switch bases and herd from meny ppl that eldelbrocks the one who makes that base and it flows likE **** so yea lol i need to do something to this car quick and ina hurry i just got back from the track and ran a 15.10 best!!!
im pissed!!! i dont have injectors or throttle body actuly on it yet but i do need to switch out injectors bad its got the originals from 87!!!! but besides wantin to put an LT4 hot cam in it i wanna know about the heads are the L98 vette alum. heads worth my time??
Car: 1992 Camaro RS
If you've got the vette heads in it I'd just leave em alone. You'll make more power with Vortecs, but not a massive amount more. I almost want to trade my vortecs for some vette heads just so I can take 50 lbs off the car.
Regardless, you can get into the 12s with those heads if you put a big cam in it. Cam gearing, and stall should get you there I would bet.
On Probation
Engine: several
Transmission: none
Axle/Gears: none
It's easier to port the vette heads to big flow, but there's nothing wrong with the Edelbrock base. It does benefit from Extrude-Honing, but so would your current heads and intake base.
Car: 87 IROC-Z28
Would it be worth extrude honing the edelbrock base for a stock set of vortec heads?
Edit: At $435 for honing it's out of my price range anyway. I'd be better off selling my new manifold and going with a stealth ram instead. Unfortunately it won't clear my STB.
On Probation
Engine: several
Transmission: none
Axle/Gears: none
STBs are way overrated. It's just unnecessary weight, which is bad, up high, also bad, and relatively far forward in the car, also bad. Sell it to some ignoramus. I've seen full-competition-only third gens pull 1.2gs lateral without one. No stress cracks after a dozen seasons, either. That's more than enough evidence.
Car: 87 IROC-Z28
I understand what your saying. In my case I think the STB did make a difference. I definately could feel the difference with race tires on. Car seems more responsive and predictable in turns. My car is set up for autocrossing and track days.
Besides I now have holes in my strut towers and I'd rather leave the bar on to cover the holes.
Car: 87 IROC-Z28
Yes there is. Unfortunately it won't work with my vortec heads.
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Actually, it's easier to adapt it to Vortec heads than to L98 heads, but with the right reworking, it has even been adapted to those. If you want power for cheap, and keep the STB, it's your only option. Because the TPiS Mini-Ram is far overpriced.
Car: 87 IROC-Z28
I've checked into the TPIS mini ram and yes, out of my price range.
I'd not seen that the LT1 intake could be adapted for wortec use. I'll check into that.
Car: 87 iroc-z
Engine: B2L
Axle/Gears: 3:27
i dont have the aluminum L98 vette heads i got the big 194;150 heavy cast heads i wanna know if getten a set of the vettes is worth my time and money keep in mind i wanna go 12s with hott stock **** not 16g in aftermarket **** soo yea
Hotrodboba400
Dec 10, 2019 07:07 PM
92projectcamaro
Jan 18, 2016 08:00 AM
