Identify this part
Old Jul 14, 2010 | 12:35 PM
lo2's Avatar
lo2
Identify this part
So i just bought a 1985 camaro iroc-z and well frankly i dont know anything about it. Ive only owned newer imports. Te car starts fine, but sometimes it runs a little crappy and when i let off the gas, the rpms nearly drop all the way to zero. Anyway, i just needed to know what this part is, because it looks important, and it runs to things with electrical plugs on it. But there is no belt on the pully. Any help would be great.
Old Jul 14, 2010 | 12:38 PM
Convoy25's Avatar
Car: 95 Z85 S10, 99 Formula
Engine: 4.3 CPI , LS1
Transmission: NV3500, T56
Axle/Gears: 3.08, 3.42
Re: Identify this part
egr and the pulley on the bottom is the a.i.r pulley? either way its emissions crap.
i just cut the belt =) (v-belt) and took it out
Old Jul 14, 2010 | 12:42 PM
lo2's Avatar
lo2
what did you do with the electrical connectors?
Old Jul 14, 2010 | 01:06 PM
Convoy25's Avatar
if you can, tuck them into the crush tubing
Old Jul 14, 2010 | 01:40 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
The top circled part is not EGR, it's the valve for the A.I.R (smog) pump. EGR is on the intake.
Old Jul 14, 2010 | 01:43 PM
bradley23150's Avatar
Car: 83 Trans Am / 96 Jeep XJ
Engine: 355 / 4.0 I6
Transmission: TH350 / Auto
Axle/Gears: 3.23 10-bolt / 4wd
No.
The first circle is the Diverter valve. It is part of the emissions equipment. It costs $450 to buy one brand new, I threw mine in the garbage. It "shouldn't" be removed, especially if your state does emissions testing. But this part will not cause the motor to run poorly.
The second (lower) circle is your smog pump. Again, part of emissions equipment, and won't cause your motor to run poorly if it isnt hooked up.
Old Jul 14, 2010 | 09:38 PM
lo2's Avatar
lo2
alright thanks, i guess i may as well remove it.
But what can make my car run poorly then?
Also if it runs for a while (longer than 30 minutes) it starts running a little hot.
Old Jul 14, 2010 | 09:51 PM
rgarcia63's Avatar
Car: 88' IROCZ
Engine: 388 TPI Motown 350 Race block
Axle/Gears: 2.77
I don't why the A.I.R pump is called a smog pump it doesn't pump smog, it supplies fresh air to the exhaust ports, and the catalytic converter to decrease the smog.
Old Jul 15, 2010 | 12:29 PM
Convoy25's Avatar
sorry i never made it a point to figure out which was which on my car, none of it worked, and half was already cut up when i got it, so i just grouped it all into emissions junk.
LT1Formula
20
Nov 14, 2015 12:02 AM
Linson
Aug 21, 2015 02:12 PM
armybyrd
Aug 17, 2015 08:59 AM
GVMV
Exterior Parts for Sale
Aug 16, 2015 07:08 PM
1nastygta
Aug 8, 2015 07:38 PM
