Battery keeps dying overnight!
Old Jul 18, 2010 | 01:18 PM
sacto92camaro's Avatar
Car: 92 Camaro rs
I bought this camaro a few weeks back and it drove home fine. The next morning when I tried starting the car the battery was dead. I charged it and it stayed charged for most of the day. Next day same problem, this time I turned the alarm off and it stayed charged longer. I don't think the alarm is the cause of the problem but it seemed like its helping drain it faster.
Attached Thumbnails Battery keeps dying overnight!-dsc04614.jpg   Battery keeps dying overnight!-dsc04615.jpg
Old Jul 18, 2010 | 01:24 PM
Car: 92 Camaro rs
Re: Battery keeps dying overnight!
The second picture shows a wire I didn't know was about. It runs into the fuses so I'm guessing it's the alarm. bad wiring job though if you ask me.
Old Jul 18, 2010 | 02:08 PM
built91Z28's Avatar
Car: 1991 Camaro Z28
Engine: 357, Canfield heads, solid roller,
Transmission: Upgraded 03 Cobra T56
Axle/Gears: 9" 3.50 gears and Detroit Locker
Get a test light. Disconnect the negative battery cable. Make sure your doors are shut, alarms off, all that stuff. Now connect the test light between the negative battery cable and the negative terminal on the battery. If you have a drain, the light will light up. Now start pulling fuses out one by one. If you pull a fuse and the light stays the same, put the fuse back in. If you pull a fuse and the light goes out or dims a lot, your drain is in that circut. Find out what that fuse powers and start searching then.
Old Jul 18, 2010 | 04:59 PM
Dizturbed One's Avatar
Car: 92 RS
Engine: a slow one
Transmission: a crunchy one
Axle/Gears: a whiny one
Before you do what Built91Z28 says, I would first check the oil pressure switch and the domelight wiring. These are very common to cause a drain to kill your battery overnight.
Old Jul 18, 2010 | 09:05 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
Gunk in the cig lighter socket can do it also, a few years back there was a rash of car fires from that on the classic boards.
Old Jul 19, 2010 | 12:52 AM
Car: 92 Camaro rs
Thanks I'll try that tomorrow morning. This is the car by the way. I couldn't find the introduction section or anything like that.
Old Jul 19, 2010 | 01:44 AM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
Axle/Gears: Stock IRS
you can also disconnect your battery overnight and see if your battery is dead or not in the morning, at least to rule out you just have a bad battery now.
Old Jul 19, 2010 | 11:32 AM
tr6guy's Avatar
Car: '72 Triumph TR6, '85 Camaro
Engine: 2.8 V6
Had the same problem on nearly the same engine just the other day. Did like they all say - put an ammeter across the neg terminal and start pulling fuses. My problem was in the accy circuit. Someone left the trunk light turned on. Killed the battery overnight. Good luck! you'll find it.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
92firebirdguy
Sep 1, 2016 07:53 AM
z28joe2
Sep 28, 2015 05:54 PM
Lmancha96
Sep 25, 2015 08:11 PM
lanceflame44
Sep 25, 2015 12:28 PM
