How to pull the gas tank in a 92 camaro
Old Jul 18, 2010 | 11:54 PM
david068513's Avatar
Car: 1992 z28/1992 RS heritage edition
Engine: 350 tpi, 305 tbi
Transmission: 700R4,T5
Axle/Gears: G92
Its a 92 Rs, I believe the neck has broke were it connects to the tank cause it was leaking under the car when you try and put gas in it. Either way I have to pull the tank cause the fuel sending unit went out also.
Old Jul 19, 2010 | 09:23 AM
HF_monster's Avatar
Car: 86' z28 (died 5/1/11) 76 k10 pickup
Transmission: th350
Axle/Gears: 3.73 open
Re: How to pull the gas tank in a 92 camaro
put the car on jack stands by the frame not the rearend remove the rear panhard bar and the shocks also the 2 bolts that hold the torque arm drop the rear as far as it will go and undo the two straps holding the gas tank then you should have enough room to move it around and get it out with the filler neck disconnected from the body.
Old Jul 19, 2010 | 09:41 AM
built91Z28's Avatar
Car: 1991 Camaro Z28
Engine: 357, Canfield heads, solid roller,
Transmission: Upgraded 03 Cobra T56
Axle/Gears: 9" 3.50 gears and Detroit Locker
You also have to remove the gas tank door and the plastic piece in there.
Old Jul 19, 2010 | 12:46 PM
1ADan's Avatar
Car: 1987 Trans Am
Engine: LQ9/L92
its gonna be very heavy if you've got a lot of gas in there. i used the obd connector to run the fuel pump and drain some of the gas out. will definitely make a difference if you're doing this on the ground
Old Jul 19, 2010 | 03:17 PM
Axle/Gears: G92
Ok thanks, also is it true there is a gasket from the neck to the tank? I believe it is leaking gas there when you try to fill it up.
Old Jul 19, 2010 | 03:30 PM
built91Z28's Avatar
The filler neck does not disconnect from the tank. Its all one piece. If its leaking there, there is a crack somewhere.
Old Jul 19, 2010 | 03:34 PM
Axle/Gears: G92
Intresting a shop told me there is a gasket there
Old Jul 19, 2010 | 03:37 PM
ASE doc's Avatar
Car: 87 IROC Z28
Engine: 355 cid TPI
Transmission: Custom Built 700R4 w/3,500 stall
Axle/Gears: QP fab 9" 3.70 Truetrac
I beleive I may be the one who originally told you to look at the "grommet" between the neck and tank. If so, I appologize. Our third gens do not have this grommet. The neck is welded to the tank and if this seam is broken you will either need a new tank or find a welding shop that will take on a fuel tank repair.
Old Jul 19, 2010 | 04:48 PM
cIaRmOaCrZo's Avatar
Car: 86' IROC-Z....and 5 other 3rdgens
Engine: 383 hsr
Transmission: built 700r4
Axle/Gears: stock 3.23, 10bolt
i never had to remove the shocks, or torque arm bolts to do mine.
i had to remove the shield cover, panhard bar, the plastic piece in the gas door, tank straps, and then "slightly" bend the filler neck with a pry bar. (not even a whole inch)
Old Jul 19, 2010 | 04:55 PM
Stephen's Avatar
Car: 87 GTA
Neat! Which 2 connections in the ALDL (never heard it referred to as OBD) connector will fire up the pump? Won't help the OP or even most people, as a faulty pump is the reason for dropping the tank, but it is still useful info to have!
Old Jul 19, 2010 | 05:27 PM
ASE doc's Avatar
Car: 87 IROC Z28
Engine: 355 cid TPI
Its not 2 connectors. If you apply 12v to terminal G, it will activate the fuel pump. This is also known as the fuel pump test terminal.
Old Jul 19, 2010 | 07:32 PM
Axle/Gears: G92
This is gonna be fun, I hope I have enough gas to go to the shop
Old Jul 19, 2010 | 07:50 PM
bm87ta's Avatar
Car: 87 TA
Engine: 305 tpi
Transmission: auto
lower left term, term g i believe
Infested
May 22, 2018 11:56 PM
Andrew6.688
Dec 13, 2015 10:59 AM
mustangman65_79
Sep 1, 2015 03:51 PM
AkDrifted
Aug 17, 2015 07:45 PM
kyleb24
Aug 15, 2015 08:24 AM
