heat/water issue?
Old Jul 19, 2010 | 05:07 PM
PTop's Avatar
heat/water issue?
i drove to shoppers to pick up some things in my 90 IROC z28 camaro, and as i get back in the car to go home, it gives a little more trouble than usual starting, then it stalls out as i put it in drive which never happened before. so i started it up again, resulting in another stallout. 3rd time's a charm....but not so much. the 4th time i got it started, i revved it in park a little bit, to get it running, and then i got it home no problem. I even tried forcing a stallout when i got home, but it kept running. I have no clue what could be going on here. I have a new battery, half a tank of gas, and cleared out my whole air intake, so the fire triangle is there. I even wd40ed all the electrical plugs a couple days ago, although i will mention it rained last night. could water be the issue? I think i should also mention that when it sits in the sun the engine wont even turn over, but i feel thats the case with any car... Please help me you guys always know whats up
Old Jul 19, 2010 | 07:02 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: heat/water issue?
I've never ever heard of any car not turning over after it sits in the sun - have no idea what you're trying to describe here. I'm 45, so I have 30 years of daily going to work in many different cars that sat in the sun all day, even on 100+ degree days, and they start right up first time (unless there's an issue other than sun).
Old Jul 19, 2010 | 09:17 PM
PTop's Avatar
well to give you an idea i am 21 years old and VERY inexperienced, and this is my first "me" car. anyway, i cleaned all the connections on the distributor cap and everything is just fine.
Old Jul 20, 2010 | 05:41 PM
ASE doc's Avatar
Car: 87 IROC Z28
Engine: 355 cid TPI
Transmission: Custom Built 700R4 w/3,500 stall
Axle/Gears: QP fab 9" 3.70 Truetrac
Be carefull with solvents, WD-40 included, on your engine's electrical connectors. Your vehicle uses weatherpack connectors which are protected against moisture and oxydization by rubber seals. These seals can be damaged by exposure to certain solvents.
The distributor connectors will not affect starter activation. Things that could cause your starting system to fail after long periods in the sun include the battery, the starter, wiring connections between the battery and the starter. Also, your car has a VATS system. Heat soaking may be causing your VATS system to malfunction. This isnt normal and could get worse.
gta892000
Aug 11, 2019 11:16 AM
MM2Robinson
Oct 1, 2017 09:16 AM
nova983
European Region
Nov 2, 2015 12:15 PM
TheTraut88
Sep 11, 2015 05:16 AM
Fronzizzle
Sep 8, 2015 12:10 PM
