Good Setup for 400???
Old Jul 20, 2010 | 07:11 PM
Crazy88's Avatar
Car: 1992 B4C 1LE, 1992 5spd TBI
Engine: 400, 305
Transmission: Tremec 3550 TKO, T5
Axle/Gears: 12 Bolt Moser 3.73, 10 Bolt GM 3.08
Here is my build list and i'm just wonering if you guys would change any of it or have any information on quality of the parts. Plus if you have any guess of what i would be close to making power wise. Thanks
400 freshly bored .030 with all the other block prep
This is what i'm leaning to.
SCA-1-41405 Scat forged crank, forged 6in. rod, forged flat top pistons
-AFR-1038 AFR 195cc SBC Eliminator Street Heads are fully CNC-machined 75cc combustion chamber. 2.050 intake valve, 1.600 exhaust. Operating Range 2,000-6,500
-EDL-5001 Intake Manifold, Torker II, Single Plane, Aluminum, Natural, Square Bore, Operating Range 2,500-6,500
-CCA-CL12-770-8 COMP Cams Xtreme Energy Cam and Lifters, Mechanical Roller Tappet, Advertised Duration 274/280, Lift .564/.570 Operating Range 2,200-6,200
-TCI-240901 TCI Torque Converter, Breakaway 2,400-2,600 Stall
-CCA-2100 Timing Chain and Gear Set, Magnum, Double Roller, Steel Sprockets
-CCA-7372-16 Pushrods, Magnum, Chromemoly, Heat-Treated, 5/16 in. Diameter, 7.800 in. Length
-SCP1002BL Rocker Arms, Stud Mount, Full Roller, Aluminum, 1.6 Ratio, 3/8 in. Stud
Old Jul 20, 2010 | 08:53 PM
Re: Good Setup for 400???
Bad intake, been losing racing for decades now, on the track and on the street.
Use a Performer RPM instead.
I'd suggest the 3100 timing set, which is actually roller, instead of the "truck roller", which is not a roller at all but rather, bushings.
Don't buy push rods until you've assembled the engine and checked for optimum length. Those stock length ones will probably turn out to be too short. They're probably "enough" push rod in terms of strength and all that, just, you have NO WAY to know what the optimum length for YOUR particular pieces of metal will be, until they're all together. Having solid lifters makes the measurement a piece of cake.
Rest is good. If you've never had a solid cam before, you'll LOVE it.
Old Jul 20, 2010 | 10:05 PM
Crazy88's Avatar
Engine: 400, 305
I was wondering about that timing chain. Thanks for letting me know. The one bad thing about the intake is i had already had it from the guy i bought it from. How badly will it perform. it seemed to be ok when it was on the engine before.
Old Jul 21, 2010 | 07:24 AM
Atilla the Fun's Avatar
On Probation
Engine: several
Transmission: none
Axle/Gears: none
check out post #8 of this thread: https://www.thirdgen.org/forums/engi...st-builds.html
Old Jul 21, 2010 | 09:20 PM
Crazy88's Avatar
Engine: 400, 305
I'm going in tomorrow morning to start the build. Anybody else want to help out??
Old Jul 22, 2010 | 10:58 AM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
Dismal intake. The only reason people use them now is because they already have them. From a guy who "swears by it" -- yet sells it cheap (hint hint).
Sofakingdom - Welcome back buddy. Where'd you evaporate to in the last two years?!?
Old Jul 22, 2010 | 02:13 PM
mcbchild's Avatar
Car: 1984 Firebird SE
Engine: 388 sbc, Brodix Track 1s
Transmission: turbo 350 transmission
Axle/Gears: 4.10 gears
Need more info: What trans are you using and what rear gear do you have? If it plan to use this as a daily driver, hwy alot or how do you plan on using this motor?
Old Jul 22, 2010 | 04:18 PM
Crazy88's Avatar
Engine: 400, 305
weekend fun car. th350 3.42 gears
Old Jul 23, 2010 | 06:52 AM
mcbchild's Avatar
I would stick with the 1.5 Roller rockers and maybe look at getting a stall around 2800. A stall around 2400-2600 is not much more than a stock converter with is around 2000-2200. 2800-3000 stall is still a good street coverter and with your gears and tranny, will have a nice off the line seat of the pants torque. Remember, using a foot brake with a stall usually cuts ur stall off the line to maybe around 700 rpms. So if you setup is making power in the 2200-6200 rpms, then a stall with around 2800 rpm will drop to around 2100-2200 with a foot brake. 2800 stall would be perfect. 1.5 rockers with that cam is perfect. 1.6 Rockers would increase the cam lift at raise the power range of the cam, but then you have to start measuring valve to piston clearance when increasing the cam lift. These are just to be safe figures and only suggestions. Hopefully this will help you a understand a little bit more. Definitely do not get the Torker II install. Stick with a dual plane manifold. The Performer RPM would be perfect to around 6300-6500 rpm. Have you decided what compression you will be using? 10.1 would really be perfect with this setup and can still run pump gas.
Old Jul 23, 2010 | 12:32 PM
Crazy88's Avatar
Engine: 400, 305
yes its going to be pump gas in the 10.1 range. Thanks for the information. Do you guys have clearance problems with other intakes with the stock hood??
Old Jul 28, 2010 | 08:23 PM
Crazy88's Avatar
Engine: 400, 305
what intakes and air cleaner setups do you guys use under your stock hoods??
customblackbird
Aug 15, 2021 10:16 PM
Terrell351
Jun 13, 2021 01:13 PM
camaro71633
Sep 1, 2015 10:24 AM
lakeffect2
Aug 23, 2015 08:44 AM
Street Lethal
Aug 13, 2015 08:28 PM
