What kind of oil do you run in your third gen engines?
Car: 1991 Camaro RS
Engine: 305 v8 TBI
Re: What kind of oil do you run in your third gen engines?
If you live in a cooler climate, use 5W-30. If you live in a warmer climate, use 10W-30.
I use Castrol GTX High Mileage, 5W-30. My 1991 Camaro has 120 K, and still runs like new, No leaks. The car's had 5W-30 running through it for 21 years.
Car: 86 IROC Z, 92 RS
Engine: 305 4bbl, 305 TBI
You just had the oil changed at the dealer, and it's not running as good now? I would take it back and tell them.
Car: 87 GTA
Engine: 5.7 TPI
Axle/Gears: 3:27 BW 9 bolt
I've been using Valvoline MaxLife 10w-40. I have the typical leaky valve seals, although this oil doesn't cure that.
Thinking of trying out the new Quaker State Defy.
Car: 1984 Trans Am L69
Axle/Gears: 3.42 10 Bolt Posi
Rotella T 10w-30 it still has 1200ppm of zinc but I am thinking of adding some lucas zinc next change just for cheap insurance.
Car: 87 IROC Z28
Engine: 355 cid TPI
Transmission: Custom Built 700R4 w/3,500 stall
Axle/Gears: QP fab 9" 3.70 Truetrac
I think I saw where Edelbrock is producing a high zinc oil for flat tappet motors.
Transmission: 4L80E/4L80E
