Got myself a new car
Old May 23, 2012 | 08:35 AM
randy3463's Avatar
Car: 1991 Camaro RS
Engine: V8
Transmission: 5.0
Axle/Gears: Std
So the other day I sold my 90 Camaro RS v6 and bought a 91 Camaro RS v8 believe its a 305.
Was wondering if anyone here could point me in the direction of somethings that would give me better HP and/or MPG. Yes I know they contradict each other lol.
Old May 23, 2012 | 08:59 AM
Lt1Chris's Avatar
Car: 01 Acura TL
Engine: 3.2 Vtec
Transmission: 5 speed
Axle/Gears: ?
Re: Got myself a new car
Bolt ons? headers,msd cap and rotor,8.5 msd wires.
Old May 23, 2012 | 09:28 AM
heat seeker's Avatar
Car: 89 Formula
Engine: 383 SBC/HSR
Turbo.......he, he.
Old May 23, 2012 | 09:41 AM
conlinj's Avatar
Full tune up including o2 sensor, msd 6a/al, open element air cleaner since its a tbi. Also you could bump the timing up from 0-6 degrees if you run good gas.
-Jim
Old May 23, 2012 | 09:48 AM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
headers and catback help both.
Old May 23, 2012 | 10:58 AM
randy3463's Avatar
Car: 1991 Camaro RS
Engine: V8
Transmission: 5.0
Axle/Gears: Std
What exactly is a msd cap and rotor and 8.5 msd wires?
Sorry I'm not exactly car savvy. Only knowledge I have is when I have to replace things because I'm not paying a shop 75 an hour.
-Jim
When I bought the car I was told the timing is already bumped up 3. What is the standard degrees and is it above or below?
Old May 23, 2012 | 02:04 PM
Lt1Chris's Avatar
Car: 01 Acura TL
Engine: 3.2 Vtec
Axle/Gears: ?
distributor cap and rotor button under it and full spark plug wires set u can do that yourself with eas. price wise you're looking at about 300 get it from autozone it way cheaper then buying it from the venders
Old May 24, 2012 | 08:24 AM
randy3463's Avatar
Car: 1991 Camaro RS
Engine: V8
Transmission: 5.0
Axle/Gears: Std
Anyone know what the timing is supposed to be at? and is it above or below center. Was told it was bumped up 3 but no gurauntee that it was done correctly.
Old May 26, 2012 | 10:50 PM
randy3463's Avatar
Car: 1991 Camaro RS
Engine: V8
Transmission: 5.0
Axle/Gears: Std
Bump
Old Jun 13, 2012 | 08:00 PM
randy3463's Avatar
Car: 1991 Camaro RS
Engine: V8
Transmission: 5.0
Axle/Gears: Std
another bump
Was told recently about this spacer plate that I could put on the top part of my engine under my airfilter that would increase my MPG? Anyone know what exactly is meant here. Heard it at the bar but wasn't told much about it.
Old Jun 13, 2012 | 08:12 PM
randy3463's Avatar
Car: 1991 Camaro RS
Engine: V8
Transmission: 5.0
Axle/Gears: Std
Searched Spacer Plate on autozone.com and got this
http://www.autozone.com/autozone/acc...ier=54556_0_0_
found ones up to 3 in i think. not sure what the differences they make or what they actually even do.
Old Jun 13, 2012 | 09:27 PM
munk20's Avatar
Car: 1991 Z28
i think this is what they were referring to, i dont know if this is the exact one you would need or not
a buddy of mine had one on a tbi camaro many years ago. itgoes between the tbi and intake manifold for mild hp gains
http://www.summitracing.com/parts/TRD-2733/
Old Jun 18, 2012 | 06:19 PM
randy3463's Avatar
Car: 1991 Camaro RS
Engine: V8
Transmission: 5.0
Axle/Gears: Std
Would this cause any kind of MPG increase?
Old Jun 18, 2012 | 06:30 PM
Atilla the Fun's Avatar
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Stick or automatic? Current MPG? I bought a '91 RS LO3 / auto, came with a Flowmaster 80-series 2.5" muff. I averaged 23 MPG. I swapped a 3.42:1 axle for better acceleration and less down-shifting out of OD, re-calibrated the speedometer, and still averaged 23 MPG, with a best tank of 25. In other F-cars I've owned, I always got best MPG with 3.08:1 gears and 26" tires with 700R-4s. Always better than 2.73:1. Always.
Frozer!!!
Jan 19, 2024 04:55 PM
Reddeath210
Oct 6, 2015 08:20 AM
Linson
Aug 21, 2015 02:12 PM
kyleb24
Aug 15, 2015 08:24 AM
bryan623
Aug 10, 2015 11:33 AM
