Replacing Timing Chain
Old Jul 22, 2010 | 05:23 PM
JTNKTZ's Avatar
Car: 1991 Camaro RS/1989 Vert RS
Engine: 355/350
Transmission: T-5/T-5
Axle/Gears: BW9bolt3.45posi/3.23 Posi
I am still learnign so bare with me.
I am going to replace the timing chain while I have it out so I have a few questions.
My cam gear has 2 sprockets so does that mean I need a Street true roller timing chain; Double roller?
http://www.autozone.com/autozone/par...3_9993_0_58670
Also I'm putting this cam in (Its a flat tappet where as the timing chain says its a true roller timing chain would that effect it?):
EDIT: Would this timing chain work?
http://www.summitracing.com/parts/CCA-3030/
Old Jul 22, 2010 | 07:10 PM
Atilla the Fun's Avatar
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Re: Replacing Timing Chain
You don't want just the chain, you want the whole set. Cheaper that way anyway. Look; http://www.summitracing.com/parts/CLO-C-3023X/
specialized
Jun 18, 2022 09:26 AM
Vintageracer
Jan 10, 2020 05:33 PM
drewdock87
South Central
Aug 18, 2015 09:02 PM
MY87LT
Aug 17, 2015 08:43 AM
Leggman1
Brakes
Aug 12, 2015 08:39 PM
