86 lb9 roller block/post 87heads
so im working on picking up a 86 T/A tpi, lb9, auto, from a guy at work.. now ive done a lot of work on second gens but this will be the first post 81 fbody project... roller blocks were started in 87 also the head to intake surfaces chagend at the same time if im correct.. is the fact that this is a TPI moter change any of that or is this just a tpi intake designed for the 86 and back heads... and is it a roller block or not..
the guy who owns it now got it to make it the knight rider car but dosent know anything about cars so when it started over heating he just kept driving.. AZ summers are not forgiving to any engine.. turns out the fan stoped running.. (prlly a fuse or somthing stupid like that) but as is hes got cracked heads now.. i just need to know what gen of heads to pick up when i rebuild the 305... and yeah im gonna rebuild it.. i need a fun but economic car to drive in collage.. my 81 camaro is getting supercharged and the 69 c10 is for work.. for now...
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: 86 lb9 roller block/post 87heads
Other than the obvious internal differences (crank / cam ) with 1 pce seal crank , roller blocks ; the only '87+ difference is angle of two center intake bolt holes on cast iron heads and the use of centerbolt rocker covers
ok cool.. i was just making sure that the tpi moters were not an acception to the rule.. so the intake on my 86 will be different from that off an 87 regardless that its a tpi.. so my block will be a non roller 2pc RMS with the old intake bot pattern.. good deal.. thanks
Car: 82 Z28
Transmission: T400
Only difference is the bolt pattern on the intake base ;pre / post '87.Everything else on intake is the same
ok so im looking at a most likley a 1pc RMS with pre 86 heads/intake bolt pattern.. and non rollers... wow ill deff have to wait till i pull it apart to order a rebuild kit.. haha id rather not guess.. thanks guys
KO1
16
Oct 15, 2015 05:00 PM
