Hard Brakes
Old Aug 2, 2010 | 08:58 PM
Darkfire438's Avatar
Car: 1985 Iroc-Z
Engine: 305 4bbl
Hard Brakes
i drove my 85 iroc today to burger king and everything worked just fine, i got there shut it off and came back out about 20 minutes later and for some reason my brakes feel like im stepping on a rock, i can barely press it down, whats causing this
Old Aug 2, 2010 | 09:16 PM
ms87iroc's Avatar
Car: white 87 iroc-z
Engine: 5.7 tpi
Axle/Gears: 3:27
Re: Hard Brakes
My 83 is doing the same thing, my buddy told me it could be master cylinder or distribution block, i guess start with the lesser of the two in cost. I pulled the brake line off on front passenger caliper and had no fluid come out.
Old Aug 2, 2010 | 09:45 PM
92RS_Ttop's Avatar
Car: 1992 Camaro RS
Engine: Rebuilt 350 going in after paint
Transmission: WCT5, 7k & counting behind the 350
Axle/Gears: 4thgen disc rear w/ 3.73 Posi
Re: Hard Brakes
Have you checked the vacuum line to the brake booster and the booster itself? A leak in either one of those will give you a real hard pedal as well.
I doubt its the master cylinder since that usually gives you a real soft pedal that goes to the floor before you feel the car start to slow down when it goes bad.
Its also possible you have a crushed or blocked line steel line, or a rubber line that has come apart internally and is now blocked.
Old Aug 2, 2010 | 09:53 PM
built91Z28's Avatar
Car: 1991 Camaro Z28
Engine: 357, Canfield heads, solid roller,
Transmission: Upgraded 03 Cobra T56
Axle/Gears: 9" 3.50 gears and Detroit Locker
Re: Hard Brakes
I would check the vacuum line and check valve. You may want to post this in the brake section. May get better responses there.
Azrael91966669
25
Jun 20, 2017 04:04 AM
86White_T/A305
Aug 17, 2015 12:16 AM
Leggman1
Brakes
Aug 12, 2015 08:39 PM
MustangEater82
Brakes
Aug 11, 2015 07:52 AM
