what motor is this...
Old Aug 3, 2010 | 09:49 AM
bocaj25's Avatar
I bought a 88 camaro RS the other day, guy said that someone before him swapped the motor out with a 350.... curious as i am i wanted to check the casting number to make sure it was a 350, now the only thing i can find on the motor is 5.7LG SGI and i was wondering if there is anything special about this motor or do i keep buying parts for it as if it was a 1988camaro 350?....tried looking it up and cant seem to get a straight answer, heard everything from truck motor to corvette motor... help please really want to upgrade this thing
Old Aug 3, 2010 | 10:47 AM
1ADan's Avatar
Car: 1987 Trans Am
Engine: LQ9/L92
Re: what motor is this...
what is the casting number on the motor? may help us do some digging for ya. www.mortec.com is a great source for engine specs as well
Old Aug 3, 2010 | 02:06 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
moretec is gone! Have to search "chevy casting numbers" and find another site.
5.7 designates it as a 350, but we need casting numbers to know what year range - driver side rear of block behind/under head - it's almost impossible to see in the car, but it's there - try a flashlight and a mirror.
Old Aug 3, 2010 | 02:32 PM
1ADan's Avatar
Car: 1987 Trans Am
Engine: LQ9/L92
oh man, that was such a great place. i was able to dig up most of the info off the wayback machine (great internet archive), so if we can get some casting info, i still may be able to help
Old Aug 3, 2010 | 07:37 PM
bocaj25's Avatar
i found what looks like 0F164 next to the GM5.7LG SGI
Old Aug 4, 2010 | 07:50 AM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Is a late model, one piece seal crank , 350 block
Most likely roller cam
Block casting # is on other side behind pass side head
As you have found out , one block casting may have been used for many different engine combos; Truck / HiPo / 2 or 4 bolt mains so only way to tell exactly what engine is ,
is to look at 2 or 3 letter code stamped on the block pad at front of pass side head
Tells year / Hp / trans / original vehicle
Old Aug 4, 2010 | 08:01 AM
1ADan's Avatar
Car: 1987 Trans Am
Engine: LQ9/L92
(disregard)
Old Aug 4, 2010 | 10:09 AM
bocaj25's Avatar
so i looked where this pictures is showing, and the A/C pump is in the way but looking behind it with a flashlight mirror and engine degreaser still nothing....
Old Aug 4, 2010 | 10:12 AM
1ADan's Avatar
Car: 1987 Trans Am
Engine: LQ9/L92
you definitely should have a casting number on the back of the motor on the driver side. it may be covered in dirt and grime, but its definitely there
hydrolic144
Sep 8, 2015 06:55 PM
greenyone
Aug 29, 2015 11:08 AM
Randomtask2
Aug 26, 2015 03:34 PM
slade5612
Aug 11, 2015 07:19 PM
Thaney9
Aug 7, 2015 08:25 PM
